May 30th, 2007, 08:18 AM
#21
STOCK EXHAUST MODIFIED AND HMF GONE........
yes. depends what you call tough. yes
07 BF 650i
112ss
26" Mudwisers
Dynatek CDI
Swaybar Removed
May 30th, 2007, 07:48 PM
#22
how much power gain do u think everyone is getting? also what size of jets will i need? Anyone have a sound clip? My brute is mostly stock with the exception of the stuff in my sig. the only performance mod would be the dynatek cdi. I was looking into the hmf exhaust but from what i've heard some are disapointed with them. So if i can make my stock exhaust sound good and gain as much power i will be happy. Plus if it is just gunna cost me a jet kit and a few hours labour why not.
2007 Brute Force 650i
May 30th, 2007, 08:00 PM
#23
I got a stock muffler from mudlift and plan on doing somthing similer to this to it.
Also going to make a better heat shield so pasengers legs don't get so hot.
May 31st, 2007, 11:44 PM
#24
so let me get this straight for when i do it first there is a silencer then turbine then after that is a baffle chamber. but in you pics the one titled baffle chamber is it the the same one that you drilled the holes in becuase they look much different. one is very dirty while the other appears shiny. i would like to know the exact makeup of these before i do this. also what jetting would you recomend after soing this?
June 2nd, 2007, 06:16 PM
#25
so let me get this straight for when i do it first there is a silencer then turbine then after that is a baffle chamber. but in you pics the one titled baffle chamber is it the the same one that you drilled the holes in because they look much different. one is very dirty while the other appears shiny. i would like to know the exact makeup of these before i do this. also what jetting would you recommend after doing this?[/b][/b]
Yes that's the order they're in. I pressure washed the inside before I drilled it. That's why it looks different. As far as the jetting goes I'm at 142f / 146 r 4th clip on the needle 2 3/4 turns out. This is with a Dynojet kit. It really needs a #40 pilot because it could stand to go another 1/4 turn out. I also have the resisters removed from the plug boots. This will effect the jetting. Your jetting may be totally different when you get it done . All I can say is free up your afternoon , get a hand full of jets , new plugs and do some plug runs. Pay attention to what your plugs tell you.
BF750 Built For Business
Stock is for pansies.
June 2nd, 2007, 06:25 PM
#26
how much power gain do u think everyone is getting? also what size of jets will i need? Anyone have a sound clip? My brute is mostly stock with the exception of the stuff in my sig. the only performance mod would be the dynatek cdi. I was looking into the hmf exhaust but from what i've heard some are disapointed with them. So if i can make my stock exhaust sound good and gain as much power i will be happy. Plus if it is just gunna cost me a jet kit and a few hours labour why not.[/b][/b]
With the HMF the powers comes on with a hard hit. Very pipie. With the stock mod you get the same amount of power but the powerband is very broad and comes on allot smoother.....not as hard of a hit..but allot of torque.
June 9th, 2007, 11:22 AM
#27
Ok, I did mine almost the same as the one in the pics. The only difference is with the end cap. I didn't cut mine flush like you did. I just removed the packing in it. But I drilled holes in the one baffle behind the finned baffle and opened the fins up like you. I have one complaint about it. When you let off at a slow speed it whistles. There are no holes in the welds either. Its sealed up fine. I don't know why it does this. It sounds good under acceleration but on the decel I was disappointed. I am thinking about cutting the end off and modding the first baffle now. I guess I should have drilled holes or something. My brother modded his and the only difference in the way we did ours was he driled holes in the finned baffle and I opened the baffles up more. His sounds great on accel and decel. They do have a different sound as well when you rev it.
What do you guys think my whistling problem is?[/b][/b]
I just removed the packing and the the small pipe with all the little holes and I too have the whistling problem on decel. I am now going to try puting a pipe in the place of the pipe with all the little holes. I'll let you know if it works.
June 9th, 2007, 03:22 PM
#28
I fixed my whistle by putting a piece of 1 1/2" pipe where the pipe with all the holes was.
June 11th, 2007, 10:17 PM
#29
I removed the snorkel and attached a turndown......Very nice sound
September 18th, 2007, 01:30 PM
#30
Stogi,
Do you still have the pics of this mod? i clicked on the link and they were gone. I would like to try this mod.
2007 Brute, 29.5 x 10 Laws
Dynatek CDI, EPI clutch kit, LRD Torc Exhaust,
Custom center snorks, 2.5" spacers on all 4's
2008 Renegade 30" Silverbacks
HMF, PCIII, Custom Center Snorks, some clutch work
brute 650 sra modify stock exhaust, brute force 750 with exhaust baffle removed, brute force modified stock exhaust, brute force stock exhaust mod, cutaway view of hmf penland pro, do hmf pipes have baffles, gut brute force muffler, gutting bruteforce 750 muffler, how much power gaine from hmf exhaust, how to take out exurst baffel 750 brute force, modifie stock brute force exhaust, modified brute force exhaust, modified brute force pics, modify exhaust for brute force, modify stock wolverine exhaust, modifying brute force muffler, why does my hmf exhaust whistle, worldofbrutes
