Clutch spring install - Kawasaki Brute Forum
post #1 of 21 Old April 11th, 2007, 07:05 PM Thread Starter
Would love to upgrade my springs! Just worried I might have a problem with the install, I do all of my own work on both cars and bikes. However I have never messed with anything like this. How hard is it?
07 Brute Force 650i
27" Outlaws, Rattlesnake wheels, SSATV lift,
HMF Exaust, Moose jets & Module, 1.5" Wheel spacers
flashpoint is offline
post #2 of 21 Old April 11th, 2007, 07:33 PM
With a clutch puller and spring compressor it is all very easy. The clutch puller is almost a must though and the spring compressor can be made by a press or something, that is what we did. i would say about a 2 or 3 diffuculty level if you have the right tools.
fire1153 is offline
post #3 of 21 Old April 11th, 2007, 07:59 PM
What did you make the compressor out of?
'06 650i VDI Gen 2
Gman77 is offline
post #4 of 21 Old April 11th, 2007, 09:25 PM Thread Starter
:worthless:
07 Brute Force 650i
post #5 of 21 Old April 11th, 2007, 11:11 PM
The guy that does most of my work has a large press. We just used and flat piece of metal and two sockets. Got the spacing and welded them to the flat metal, then just compressed the spring and replaced the lock ring. Sorry I don't have any pics.
fire1153 is offline
post #6 of 21 Old April 12th, 2007, 09:33 AM
You only need the clutch compression tool if you are replacing the secondary spring. If you are replacing the primary which is usually that is sold in most clutch kits the only special tool needed is a torque wrench. Remove the primay bolt .....left hand thread. Remove the eight bolts that hold the spring cover in place. Remove old spring install new one with washers per instructions or as you removed them install cover and torque to spec 113 in/lbs. Install primary bolt torque to 69 ft/lbs. Install clutch cover and enjoy. I will try to upload a picture.
FroNt_PaGe is offline
post #7 of 21 Old April 12th, 2007, 07:33 PM
What he said is exactly true, the primary spring (what he is describing is very easy). The secondary is the one that can give a little trouble. Just in case you don't know, the primary is basically what changes your stall and the secondary spring works to hold your belt tighter, therefore if you are gonna run bigger tires you will need a secondary spring or your belt WILL slip. If you are keeping stock size then the secondary is basically up to you.
fire1153 is offline
post #8 of 21 Old April 14th, 2007, 09:54 AM
A spring compression tool is easy to make.
mudlift is offline
post #9 of 21 Old April 15th, 2007, 01:33 PM Thread Starter
Yes I see, after a ride yesterday with my 27" outlaws I fell into a hole that I should have made it throught, but my belt started slipping. So I need a secondary spring change? What spring color would yall recommend in the case that I dont wanna loose top end, just stop the slipping.
07 Brute Force 650i
post #10 of 21 Old April 15th, 2007, 11:54 PM
almond secondary and pink primary would help. if you go red your going to have a large top end loss.
2005 Kawi Brute Force 750 4x4Warn 2.5 winch 28" bugs on Type 6 wheels Pen-Lock TwinAir Filter Highlifter extreme clutch kit, hot cams, and JE HC pistons VDI CDI Mooseutility division rear bag,Rhino Lined Racks B&M Custom snorks skid plates&CVguards HMF utility dynojet kit highlifter diamond plate bumper 400ex rods and ends
bruteforcebob is offline
Clutch spring... gusmx5 Brute Engine & Drivetrain 23 July 16th, 2009 03:59 PM
Maroon Spring install Trever Brute Engine & Drivetrain 41 March 23rd, 2009 12:29 PM
Secondary clutch spring mossy Brute Engine & Drivetrain 9 July 30th, 2008 07:35 PM
Clutch kit install on BF750 stvnscal Brute Engine & Drivetrain 3 April 25th, 2008 07:41 PM
