April 7th, 2007, 07:34 PM
What will this spring combo do?
what will an epi almond secondary and pink primary spring in the clutch do with 27 xtrs? will i lose topend? more bottom end?
2007 Brute Force 650i
April 16th, 2007, 01:25 AM
Bump!
I too would like to know! I was thinking of just getting the Almond Secondary. I really need some help with this too.
2010 Black Brute Force 750i
2008 Red Polaris RZR
April 16th, 2007, 07:44 PM
HUh, I too was looking for info on the almond secondary! Just to prevent my belt from slipping. Also once installed what else needs to be done??
07 Brute Force 650i
27" Outlaws, Rattlesnake wheels, SSATV lift,
HMF Exaust, Moose jets & Module, 1.5" Wheel spacers
April 17th, 2007, 09:45 PM
I have this combo with 26 mud lites, I did not loose any top and gained lots on the bottom. I like it and would recommend doing it!!
April 18th, 2007, 12:58 PM
I am also interested in putting in the almond secondary as well. I have a gnarly set of 26'' 10 front-12 rear mud gears that i like to put on when i plan to get muddy.I know my belt slips with these tires. Just for normal riding the stock tires are fine for me. I really want to see how the almond spring will work on the stock factory wheels. I assume that putting the spring in a stock bike will make it really launch.. Has anybody put a spring in a stock.
April 19th, 2007, 08:43 PM
i run a almond secondary with a maroon primary and it is a dang good combo , it gave me a ton of low end and didnt lose that much on the top if any . but the maroon spring does have a little stall to it but it is hardly noticable
750 brute force
home made snorkels
moose cdi
maroon, almond
exhaust mod soon
April 22nd, 2007, 09:58 PM
The pink and almond is the best setup for those size tires. Keep the stock weights in and it will pull it's azz off.
BF750 Built For Business
Stock is for pansies.
April 23rd, 2007, 03:34 PM
I have already installed a i almond secondary and was wondering how much harder (if at all) installing a primary spring will be? Will i have to pull the primary clutch off to install the pink spring?
Brute Force 650 sra
KFX V-Force 700
April 23rd, 2007, 07:12 PM
I recieved my almond spring today, now I just need enough time to install it! Damn the man holding you down and making people work!
07 Brute Force 650i
April 23rd, 2007, 08:36 PM
The primary spring is easier to change. All you have to do is remove the 8 bolts on the outside of the primary and remove the end. You should then have access to the primary spring.
brute force 650 primary springs, primary clutch bump 650 bruteforce
