April 25th, 2007, 11:27 AM
#11
What will this spring combo do?
The primary spring is easier to change. All you have to do is remove the 8 bolts on the outside of the primary and remove the end. You should then have access to the primary spring.[/b][/b]
Thank you for your help.
Brute Force 650 sra
KFX V-Force 700
April 25th, 2007, 02:07 PM
#12
No problem, the only way I knew was from the help from the people on here and the people I ride with. I had my mechanic change mine the first time but I always watch what he does so I can do it myself the next. Since getting my brute I have learned a lot about it from these forums. There are a lot of good poeple on here and where I ride (Buscobeach). I am originally from Kentucky but am in the military and have found that there are nice poeple everywhere, just got to get to know them.
April 25th, 2007, 04:35 PM
#13
where can i buy an Almond secondary spring ??? im in Canada btw, if there is a place here to order it. thanks
07 BF 650i
112ss
26" Mudwisers
Dynatek CDI
Swaybar Removed
August 22nd, 2007, 10:37 PM
#14
im new to the forum . i've had my 750 for about 3 weeks and i was looking to get the 27" xtrs on 14's and i need a link so i can order the pink n almond springs . thanks i advance for any help and advice
August 23rd, 2007, 10:06 AM
#15
Here is the link. Be sure to buy the primary puller as well, $30 chunk of gold. You will need a secondary compressor as well, but that can be made easily.
<a href="https://www.erlandsonperformance.com/mm5/merchant.mvc" target="_blank">
EPI Site
</a>
August 23rd, 2007, 09:22 PM
#16
thanks for the info just order'd my springs
August 27th, 2007, 10:27 AM
#17
The pink/almond makes my 650 with a DynaTek, and 27" Mudlites pull just a little harder than it did before adding the wheels. badfish, if you have an impact wrench, use it to remove the secondary. I ordered the clutch puller from EPI too, but could not for the life of me get the primary to pop loose.
August 27th, 2007, 05:45 PM
#18
LH thread ??? i did order the puller im wait'n on the ups truck i havent taken anything apart yet i was going to do the clutch n tires at the same time
August 27th, 2007, 06:31 PM
#19
The bolt that holds the clutch on is left hand and the puller is right hand thread. Also it is critcal that you do not over torque the bolt when putting the clutch back on.
August 28th, 2007, 10:54 AM
#20
I'm assuming that Kaw overtorqued my primary, because that sob will not come off. I have tried everything I know. I used the EPI puller...greased the threads on it....tapped it with a hammer(the end of the puller) hoping it would break it loose and cussed it....nothing worked. Anybody got any suggestions on how to remove this stubborn primary?
brute force 650 primary springs, primary clutch bump 650 bruteforce
