New air box mod on BF750 - Kawasaki Brute Forum
post #1 of 17 Old February 10th, 2007, 06:56 PM Thread Starter
This is a mod I just did and first post.
I did have the EHS racing lid but it was not very reliable when raining and mud kept covering it. So I decided to add dual 2" snorkels, made with ABS 90 degree elbows.
I found that the duals were more air than expected. I just got back from doing runs with a fuel air sensor (LM-1) hooked up to a exhaust bung. With one snorkel blocked off I'm very close to where I need to be. I'll open the other snorkel when I go into high elevations 7000 feet plus.
The testing elevation is 4200 feet and I was already jetted for the EHS lid.
I'll be trying it all out tommorow with about twenty 1-2 feet deep water crossings to go through. It will be interesting if steam is a problem. I have custom splash guards
to reduce water from wheels. For those wondering the stock snorkel is not blocked off.
air Fuel ratio 2 snorkels 35 mph 13.5:1
2 snorkels WOT 13.8-14.5:1
air Fuel ratio 1 snorkel 35 mph 13.5:1
1 snorkel WOT 12.5-13.1:1
My jets are 170 keihn F/R needle 1 shim .20
Brute 750
brute750 is offline
post #2 of 17 Old February 10th, 2007, 07:32 PM
SURE LOOKS LIKE YOU KNOW WHAT YOUR DOING I WISH I KNEW WHAT THOSE #,S MEAN LOL
05 750,2in lift, snorlkles,hmf,cdi,28 swamplites,snorkled exhaust
brutster is offline
post #3 of 17 Old February 10th, 2007, 07:41 PM
05-BF-750's Avatar
Looks good is it water Prof?
Brute Force 650 sra
Maroon primary,VFJ stage 3, 700 cylinders, Twin air filter
82mm Wiseco 11.5:1 pistons, CWR cams, Dynatek CDI ,
my crossover intake, Fan switch, K & N filter, BKmuzzy exhaust
KFX V-Force 700 SOLD :-(
http://i31.photobucket.com/albums/c3...SANY1909-1.jpg
05-BF-750 is offline
post #4 of 17 Old February 10th, 2007, 09:07 PM Thread Starter
Its not water proof if water was up to air box. This mod is for more air allowing bigger jets. To take advantage an aftermarket exhaust would help.
In the future I'm planning on a FST or FPS big bore kit. Think that is where a mod like this would really help.
Brute 750
brute750 is offline
post #5 of 17 Old February 10th, 2007, 10:08 PM
05-BF-750's Avatar
Why not use a EHS RACING AIR BOX COVERS?
http://www.ehsracing.com/catalog/product_i...&products_id=82
Brute Force 650 sra
post #6 of 17 Old February 10th, 2007, 10:20 PM Thread Starter
I tried it and it works great until in starts raining. If the brute 750 air box was under plastic like almost all other atv's I would of stuck with it. I've replaced the outerwear material twice and after 3-4 months it will let water through again. This is a cheap and safer way I think. The ABS was $2.38 for just 1. The sealer I used was 5 dollars and have lots left over. I already had the 2" hole saw bit.
I'm going to try it on a shallow river tomorrow and I will be able to tell if I need to extend the snorkels where they don't pick up steam.
Brute 750
brute750 is offline
post #7 of 17 Old February 10th, 2007, 10:28 PM
05-BF-750's Avatar
Originally posted by brute750
I tried it and it works great until in starts raining. If the brute 750 air box was under plastic like almost all other atv's I would of stuck with it. I've replaced the outerwear material twice and after 3-4 months it will let water through again. This is a cheap and safer way I think. The ABS was $2.38 for just 1. The sealer I used was 5 dollars and have lots left over. *I already had the 2" hole saw bit. *
[/b]
Well sounds like u have done your home work.
Brute Force 650 sra
post #8 of 17 Old February 11th, 2007, 01:41 AM
i would like to see how that work out
ssatvplusDiamond Plate Bumper,750 BRUTE 06 26 VAPIRE ssatvplus lift kit, K&N,pro circuitexhaust, outlaw super duty pro clutch ,dyno jet 150f 155r needle #3 http://new.photos.yahoo.com/bluthang7/albums/
bluthang is offline
post #9 of 17 Old February 11th, 2007, 02:51 AM
lol, i installed that about 5 months ago after snorkling mine with one snorkle and ricjened mine up badly, after a few ride and a good rain i saw that wasn't gonna work also. I did something similar to what you did but i added a 2nd snorkle and with the same jets you had #170's and it jetted right for the EHS lid it ran bad lean also with both snorkles open. I have a muzzy full exhaust on mine
Mines a couple of post down. Remember, the 90* elbows are facing down and will let in alot of steam!
I'll be running mine on the LM1 sometime this or next weekend to see where mine is, i know it way lean with both. later
2006 650i
Mods: 29.5's on HL Wheels, Factory's on ITP type's 7's, 2" HL Lift, Dalton O/Bl primary, custom snorkles, air box mods, HMF uility, K&N filter, 170 & 165 main jets, vdi Gen II or moose module, & Venom 3000lbs. winch
B Man is offline
post #10 of 17 Old February 11th, 2007, 06:23 AM
BRUTE650's Avatar
BRUTEWISE? is this what you were wanting to do?
650 Brute SRA
27' Executioners
HMF Penland
Moose Module
Snorkeled
1 5/8 spacers per side
BRUTE650 is offline
Clutch kit install on BF750 stvnscal Brute Engine & Drivetrain 3 April 25th, 2008 08:41 PM
06/07 BF750 Vs. 08 BF750 usmcracing General Discussion 9 March 26th, 2008 11:29 AM
Big GUn Utility for BF750 Drew T Brute Engine & Drivetrain 0 April 25th, 2007 05:29 PM
LRD Sound Clip (BF750) Polaris425 Pictures & Videos 3 March 19th, 2007 05:13 PM
06 BF750 oil leak kip Brute Engine & Drivetrain 5 December 26th, 2006 07:21 PM
