Engine Brake Fork - Kawasaki Brute Forum
post #1 of 12 Old January 3rd, 2007, 01:10 PM Thread Starter
Engine Brake Fork
Has anyone removed their's from the belt housing? I am told it will be a good improvement because it eliminates the brake at speeds slower than 3mph and get an extra 2mph at the top end.
Jake
'06 Brute Force 650 4x4i
Jake G. is online now
post #2 of 12 Old January 3rd, 2007, 07:09 PM
05-BF-750's Avatar
Engine Brake Fork
Yes I would like to remove mine as well. Anyone have any info on this?
Brute Force 650 sra
Maroon primary,VFJ stage 3, 700 cylinders, Twin air filter
82mm Wiseco 11.5:1 pistons, CWR cams, Dynatek CDI ,
my crossover intake, Fan switch, K & N filter, BKmuzzy exhaust
KFX V-Force 700 SOLD :-(
http://i31.photobucket.com/albums/c3...SANY1909-1.jpg
05-BF-750 is offline
post #3 of 12 Old January 11th, 2007, 09:21 PM
Engine Brake Fork
i just removed mine it was easy to do, i just got my 750 back with a fresh motor so i still have to break it in. i,m hoping to have good result without it.the only thing is i don,t know how to stop the 2w 4w light flashing back and forth. if anyone give me their two cents on this that would be great!
05 750,2in lift, snorlkles,hmf,cdi,28 swamplites,snorkled exhaust
brutster is offline
post #4 of 12 Old January 12th, 2007, 01:16 PM Thread Starter
Engine Brake Fork
I just did mine as well. Actually the dealer did it while they were in there for warranty work. What he took out is a spring and the fork itself. He left the shift motor on so the lights don't come on. He told me that all he had to do is remove a c-clip and it came out.
Jake
post #5 of 12 Old January 12th, 2007, 03:25 PM
Engine Brake Fork
exactly why do you'all want to remove it? does the noise bother you?
2006 Brute Force 650i. not for sale!
1987 s10 mini tubbed,475 big block, nitrous.-for sale!
1991 corvette. factory aluminum heads/targa top.- for sale!
1995 ext cab s10 tubbed/big block.- SOLD!
jimmya is offline
post #6 of 12 Old January 12th, 2007, 11:25 PM Thread Starter
Engine Brake Fork
Originally posted by jimmya
exactly why do you'all want to remove it? does the noise bother you?[/b]
It wasn't the noise really. I removed mine for better belt life and I found it annoying at slow speeds. Because I don't have it on now my machine takes off better with less resistance.
Jake
post #7 of 12 Old January 13th, 2007, 12:27 AM
Engine Brake Fork
4wheelfurry took out my engine brake. Just remove the C clip. It actually prolongs the life of the engine brake because your not using it anymore. It will still slow down up to a certain speed. If you have any after market springs or clutch kit I recommend you do this or you will have problems with the engine brake. Just remember your driving a different machine afterwards that can freewheel.
05 Camo Brute 750, Dynatek CDI, Bayou Snorkels, Exhaust Snorkel, HL Clutch, 28" Laws and more stuff hanging around.
http://community.webshots.com/user/mudcrazee
www.southernswampboyz.com
mudcrazee is offline
post #8 of 12 Old January 13th, 2007, 01:05 PM
05-BF-750's Avatar
Engine Brake Fork
Originally posted by mudcrazee
4wheelfurry took out my engine brake. Just remove the C clip. It actually prolongs the life of the engine brake because your not using it anymore. It will still slow down up to a certain speed. If you have any after market springs or clutch kit I recommend you do this or you will have problems with the engine brake. Just remember your driving a different machine afterwards that can freewheel.[/b]
What do you mean my it can freewheel?
Brute Force 650 sra
post #9 of 12 Old January 13th, 2007, 02:05 PM
Engine Brake Fork
thanks for that info guy, know for my end of the deal remove the belt cover, then remove the 3 8mm bolt on the brake actuator, carefully pull off actuator and set aside, i didn,t unplug mine when i did it. in side the belt cover is the brake fork and spring, remove the clip at the bottom. now the brake assembly can slide up and out of the top of the belt cover. before you put the actuator back in place put some silicone on the joints of the mounting plate of the actuator, install actuator with the 3 bolts, then install the belt cover and your done. if anyone can see a mistake in my instructions feel free to add to it
brutster is offline
post #10 of 12 Old January 13th, 2007, 04:48 PM
Engine Brake Fork
like someone said earlier on this post the atv will be quicker off the line and possibly a few more mph. I read somewhere on a site can,t remember which one that if you take two identical atv,s out of the box and remove the engine brake out of one of them and race them the one without the engine brake will win every time!
brutster is offline
Clutch & engine brake Question. sharkz Brute Engine & Drivetrain 3 April 5th, 2009 06:56 PM
Changing Fork Oil Thom General Discussion 2 April 1st, 2009 03:02 PM
Rear brake/ parking brake adjustment BluelightSpecial Brute Tire & Wheel Combos 1 June 19th, 2007 10:08 PM
engine brake problem brutster Brute Chassis & Electrical 6 January 13th, 2007 09:21 AM
