clutch removal - Kawasaki Brute Forum
post #1 of 8 Old September 25th, 2012, 09:47 PM Thread Starter
clutch removal
Has anyone else had trouble removing the primary clutch retaining bolt.
I got a 2005 750 brute a few months ago.
I want to pull the primary clutch to install a new belt. Can't get the retaining bolt loose.
I'm turning the bolt clockwise like it says in the service manual to loosen the bolt (right hand threads on primary clutch)
I've tryed 3 differant 1/2" drive air impact guns and an electric 1/2" drive gun. Will not budge.
Any ideas or helpfull hints would be great
2016 Polaris RZR 900s
05 Kawasaki Brute Force 750
09 Kawasaki Versys
05 Polaris XC 800 SP
riderX is offline
post #2 of 8 Old September 25th, 2012, 10:16 PM
Its left hand threaded. That means it tightens to the left of 12:00 not right as is normal...hence the term for normal bolts.. righty-tighty...lefty-loosy. To confirm, Kawie puts arrows on the clutch face showing the direction to loosen it. Its torqued to 59ftlbs. Do not go over that as it will force the hub farther over the crank and may stretch or crack it.
You do have a puller for after you get the bolt out...right?
15 ZF 800
06 BF 750
post #3 of 8 Old September 25th, 2012, 10:36 PM
your local dealer service dept should pop it off for you with the correct tool if you take it there mine did
2005 brute force 750i rebuilt and ready for anything
jmd97ek4 is offline
post #4 of 8 Old September 25th, 2012, 11:00 PM Thread Starter
Sorry left hand threads.
The service manual says turn clockwise to loosen. The arrow on the clutch says the same thing. turn right/clockwise to loosen. That is what I have been doing and it will not budge.
I did order a clutch puller with the belt. But I need to get the retaining bolt out first.
09 Kawasaki Versys
riderX is offline
post #5 of 8 Old September 25th, 2012, 11:13 PM
Don't use an impact, use your torque wrench and tire-iron through the posts to hold it. Be sure to hold it with two posts not just one.
15 ZF 800
06 BF 750
post #6 of 8 Old September 26th, 2012, 06:32 PM Thread Starter
That worked better.
A 2' breaker bar spun it right out.
Still suprized my impact guns wouldn't loosen that bolt.
Thanks for the replys.
09 Kawasaki Versys
riderX is offline
post #7 of 8 Old September 26th, 2012, 07:03 PM
That worked better.
Well the deal is, its a long bolt that has pretty good torque on it. The distance between the head and the threads is enough to make an impact twist and flex the bolt between the head and threads that it acts a little springie and the impacts loose intencity by the time it gets to the threads. If the bolt was shorter it wouldn't be such a problem. Even with your breaker bar, the first inch or so movement at the end wasn't actualy moving threads yet, just twisting the bolt shaft.
It is very important to clean the crank with acetone and the hub..and touque to exactly 69 ftlbs when going back on.
15 ZF 800
06 BF 750
post #8 of 8 Old September 26th, 2012, 07:19 PM Thread Starter
Yep, I did that.
thanks
09 Kawasaki Versys
riderX is offline
