August 26th, 2010, 11:36 PM
who knows the most about 08 fuel systems
If someone could post of PM me a phone number or tell me who to talk to about 08 fuel systems please let me know. Mine is acting extremely weird and id rather explain it by voice instead of text.
August 26th, 2010, 11:45 PM
Smitty...you been wwith us sence 2007 and this is your first post! Good to hear from you. The FI system although very basic but a 32bit system isn't my thing but maybe someone will chime in with someone other then the dealer to talk to. The only things I hear about the 08 Brute's system is that they have had some problems with fuel pumps on the 08 and the screen in the tank gets plugged a lot and easly. The rest seems pretty good until there is controler failure issues. The O8s also had more issues with the crank position sencor then any other after.
August 27th, 2010, 03:34 PM
Man I guess I do not ride hard enough. I have had none of those issues with mine.
August 27th, 2010, 05:04 PM
Just some stats Thom, just a few had some problems but I am sure much of that was rider/owner operation related.
August 27th, 2010, 11:38 PM
Ive been all throught the throttle bodys, lines, had the pump out and cleaned what little I could and tons of toher stuff but I just hate to type out what its going on. Im a veteran member over at Highlifter but I couldent get a good answer over there anymore to save my life. I have worked at 2 different dealerships (kawasaki/ Yamaha and a Kawasaki/Suzuki) as a mechanic and this thing as me stumped.
August 27th, 2010, 11:47 PM
I also had a 08 750, my friend hasn't had any problems either with the FI pump or two others I know with 08 750's as well.
The Fuel pumps in some of the 08s are suffering from plastic shavings getting stuck in the fuel pump, the shavings came from when the holes were drilled into the gas tank to mount the fuel pump, the drilling shavings were left inside some of the 08 750 gas tanks causing fuel pump problems later.
Other fuel pump problems can be the owners fault too, dirt inside gas tanks, be careful when refueling.
EAGLE EYE HID's
VHOLDR 1080P Helmet Cam
Ramsey 2500# Wireless Winch
Ricochet Belly Plates
CHUCK750 HDPE footwell Skids
API a/arm Guards
Powermadd Handguards
EHS Mudder Lid
UNI Air Filter
PBR Diff Lock Button
AMStar MX-Pro Tie Rods/Ends
Trail Tech Voyager GPS unit
August 27th, 2010, 11:59 PM
May not be the FIs fault at all. There are a number of pickups and sencers that tell the controler when and what to do. Any one of those being off a bit or failing can cause it to run like hell.
EAGLE EYE HID's
API a/arm Guards
EHS Mudder Lid
UNI Air Filter
August 29th, 2010, 01:06 AM
Im guessing its not the pump, like I say its prretty weird and ever changing symptoms. thank you though!
August 29th, 2010, 04:22 PM
What kind of controller do you have on it? Still OEM or aftermarket? Do you have another one you can plug in and try or one you can borrow from someone? I agree with NMKAWIERIDER it may not be a fuel issue. Probs with the controller are hard to track down sometimes until you just change it out and then its fixed..
08 750 brute force fi oil and filter, 08 brute force fuel pump, 08 brute force fuel pump fuse, 08 brute force fuel pump fuse blown, 09 kawasaki brute force 750 fi corvette fuel pump mod, 2008 brute force 750 fuel pump cross, 2008 brute force 750fi fuel pump problems, brute force 750 fi fuel pump relay?, brute force 750 fuel pump mods, brute force fuel pump fuse, kawasaki brute force 750i error codes fi
