August 22nd, 2010, 10:31 PM
new brute
Bought a 2010 750 why is there so much noise like buzzing on the right side and clanking on the left when your giveing and letting off gas, there is a bad pause or stumble at hard take off that gets worse the warmer it gets.
August 23rd, 2010, 12:04 AM
Welcome to the site.
The stumble you better take in and have it checked out cause it shouldn't have that, but the noise on the right side is the engine brake setting itself when the key is shut off and as for the other noise, on some the beavel gear system is make like a rock-crusher transmission to take the power of the Brute. Its is not quiet but if set correctly with the right amount of play in the gears, you usualy won't hear it with a helmet on.
August 23rd, 2010, 12:24 PM
^ I agree. The stumble is not normal, especially on a FI machine. Belt whine, EBC clatter and other variuos little noises are normal.
August 23rd, 2010, 08:20 PM
I know some noise is normal but should it do it every time you touch the gas or let off when your only moving about 2 mph
August 23rd, 2010, 10:01 PM
if your just bumping the throttle on and off going slow its going to clunk around. every one of them does it. its the KEBC actuator
August 23rd, 2010, 10:02 PM
its even more notacable in 4wd when going down a hill slowly and you bump the throttle.
