August 17th, 2010, 05:48 PM
crackin sound under acceleration
Its an '08 750 and when I accelerated from a dead start it makes a crackin sound from underneath the front. What could it be
August 17th, 2010, 07:37 PM
Check the motor mounts both bolts and flanges on the rear. Mine came loose once and made a sound like that. Check the frame welds too.
August 17th, 2010, 10:37 PM
grab your driveshafts and see if there is any movement. you may have a pinion nut comming loose.
Also aftermarket skid plates will make the same sound, as the Brute frame flexes.
EAGLE EYE HID's
VHOLDR 1080P Helmet Cam
Ramsey 2500# Wireless Winch
Ricochet Belly Plates
CHUCK750 HDPE footwell Skids
API a/arm Guards
Powermadd Handguards
EHS Mudder Lid
UNI Air Filter
PBR Diff Lock Button
AMStar MX-Pro Tie Rods/Ends
Trail Tech Voyager GPS unit
August 17th, 2010, 11:35 PM
I got mine to quit that by cutting up some 3/4" heater hose in 1" strips and splitting them. Then loosened my plate brackets and slid them around the frame on both sides of each clamp then re-tightened all of them. This puts rubber between the frame and plate and holds it off the frame the rest of the way so you can flush sand and rocks out easier. I didn't do the a-arms but I could.
No more grinding...
August 18th, 2010, 01:42 AM
I haven't had any problems with the flexing with the Ricochet plates but I did w/the A.P. plates, w/those I just used a rubber gourmet inserted in the bolt mounting holes as they used the stock mounting holes from the stock skid plate. It rubber mounted the A.P. skid plates. Don't think you need to worry about the a/arm guards.
EAGLE EYE HID's
API a/arm Guards
EHS Mudder Lid
UNI Air Filter
August 31st, 2010, 04:38 PM
the rear drive shaft is moving under a little acceleration and hitting the other half of it. moving almost 1/4 of inch off of rear end and pushing shaft and making the sound. what could that be?
August 31st, 2010, 04:55 PM
I did a search of pinion nut coming loose (thanks Brian MC). There was a video from busta move and mine seems to be doing same thing. How do ya fix this problem and about how much for parts?
September 3rd, 2010, 04:02 AM
LOL fix it asap.. although mine never made any noise.. i took mine into the dealer and said spend a max of an hour and look her over... but to tighten the rear pinnion nut you need a special kawie tool to torque it to 150ftlb or something.
750 brute force poping exhaust when acceleration, brute force popping under acelleration
