Old August 9th, 2010, 06:27 PM   #1
Coolwizard's Avatar
Default Belt change question
I need to replace the belt on my '08 sometime soon. This will be my first. I still need to get a primary puller. My question is, if I use an OEM belt and keep my stock springs, is there any reason to pull the secondary? Shouldn't the deflection be in range since it will be all stock?
Coolwizard is offline
Old August 9th, 2010, 09:57 PM   #2
It likely will be in range. The best thing that you can do is put the new belt on and then check the deflection. If it is not, you can easily make a spring compressor to allow you to remove the circlip from the secondary and split the sheaves. Then you just add, or remove, shims as necessary. It takes awhile the first time you do it, but it is definitely not rocket science.
Old August 9th, 2010, 11:42 PM   #3
X2 I got lucky when I put an OEM back in I put in all the shims it ame with and it was right on first shot. Now in about fifty miles of hill climbing it stretched enough that I had to pull a thin shim out. The book says pull both with the belt and install as a unit...so why not do it by the book. Just say'n
Old August 31st, 2010, 08:54 PM   #4
Don't forget the bolt on the drive pully is left hand threads. And with an impact you can remove the driven pully in about 30 seconds, so why not. It makes it easier.
enginemech is offline
Old September 3rd, 2010, 04:07 AM   #5
bustamove's Avatar
i would highly recommended taking the secondary off for a good cleaning.. the splines can get stuck on if left to long.. then its a B@#$%ch to get off.. also every time i change deflection i also clean and re grease the dogs, roller, pins. w/e you call em inside the sheeve
bustamove is offline
Old September 3rd, 2010, 09:51 AM   #6
Coolwizard's Avatar
Thanks guys. I still haven't got around to changing it yet. I hope it holds up for this week ends ride.
Old October 8th, 2010, 10:16 AM   #7
Coolwizard's Avatar
I finally got around to changing the belt. Amazingly it didn't show much sign of wear but it was slightly stretched. The sheaves were glazed pretty good though. I got everything cleaned up and back together with no problems.
I also installed a maroon primary spring ...Wow, what a difference.
Thanks Guys for all of your help.
Old October 8th, 2010, 01:15 PM   #8
Good, glad you like it. Just wait until we talk you into an almond secondary spring..watch-out!
Old October 8th, 2010, 05:59 PM   #9
Coolwizard's Avatar
I'm already thinking about that for the Camo.
brute central belt replacement
change belt on brute video
