Old August 6th, 2010, 03:12 PM   #1
Default oil in airbox
I posted on here a while ago about getting mud and sand in my gas tank and my 09 750 was bogging out. Well I finally got around to changing my clogged fuel strainer and cleaning out the tank good. It fired right up and seemed to be running strong, but I rode it for about two minutes and as soon as it warmed up it felt really hot,and the same problem(loss of power) and I noticed after stopping that there was oil in the airbox. I know at this point its not good, and I don't have money to throw at it but am looking for input on whats wrong. Maybe its time to start saving for a big bore kit.
Oh and thanks for the help guys.
CanCrusher09 is offline
Old August 6th, 2010, 06:03 PM   #2
Oil in the airbox is usualy from wheelies or long periods of high RPMS. It comes up from the crankcase vent.
The rest still may be small particles that got up into the injectors making it very lean. Probably have to have a pro clear the fuel system.
CanCrusher09 (August 7th, 2010)
Old August 6th, 2010, 07:27 PM   #3
Is there a way to clean the injectors out without tearing them up?
Old August 6th, 2010, 09:50 PM   #4
I don't know man..I've never seen one apart. Injector cleaners can get desolvable particulates but not stuff like sand or dust from sand.
Old August 7th, 2010, 04:44 PM   #5
Oil in the airbox can also occur if you have too much oil in the crankcase. Assuming you just changed your oil, did you have it full all the way to the top of the dip stick? The V's do not like to be run full of oil. A good place to be is right in the middle of the grids on the dip stick.
The Following User Says Thank You to Adirondack Man For This Useful Post:
Old August 8th, 2010, 03:13 PM   #6
Default fuel pressure?
Does anyone know what the pressure is supposed to be for an 09 brute force 750?
Old August 8th, 2010, 05:45 PM   #7
Sorry, don't know. 14lbs in in my head but that could be from something else.
Old August 8th, 2010, 09:59 PM   #8
DLB
DLB's Avatar
Now that's new to me...I've always ran mine with enough oil to cover the grid completely, and not once have I had oil in my air box. Perhaps this is only true with the older Vs, because everything I read about these newer Brutes tells me to keep the oil level high to avoid a spun bearing or a starved cylinder.
2009 Brute 750
Almond Secondary | ASR bushings | Big Gun Evo System | Bighorns | GoPro HD Hero2 | HDPE Skids | ITP SS 312s | MSD FI Charge | Powermadd hand-guards | Prothane Sway Bar Bushings | Snorkels | Streamline Steering Stabilizer | Symtec Heated Grips | Temp Gauge | Viper Max 4500 | My Garage
http://www.youtube.com/WVGrizzly | http://www.youtube.com/ElkRiverOffRoad
DLB is online now
Old August 8th, 2010, 10:13 PM   #9
For us Brute guys we better keep it to the top of the grid screwed in and if we get oil in the box we better do the catchcan mod. I believe Adirondack Man is talking about the V-Force, Kawie's 700 sport bike. It has had more people putting catchcans on it then anything else on the web. Lots more wheeling and steep dune-riding on those things I guess.
750 brute force gas tank vent mod efi
brute force 650 catch can mod
brute force 750 oil in airbox
brute force 750i overfilled with oil
brute force gas in air box
brute force oil in airbox
gas in airbox brute force
gas in oil brute force
grizzly 125 fuel in air box
grizzly 125 oil in airbox
grizzly 650 oil in airbox
oil in my brute force air box
oil in my brute force airbox
overfilled oil on brute force
sand in oil on brute 750
sportsman 700 efi gas oil in airbox
sportsman oil in airbox
stop oil in air box brute force 750
too much oil in brute force 650
www.brute force oil in air box
