August 3rd, 2010, 10:06 PM
valve adjustment help
I need step by step how to adj valves on 650 brute.
09 brute force 650i
2500 lbs viper winch
hollowed out muffler
front spring spacers
26-12-12 rear and 26-10-12 front itp mud lite tires and itp rims
reverse lights
audio tube
HID'S
fog lights
synthetic wintch rope
cv4 battery
diamond plate front skid
more to come...
August 3rd, 2010, 10:50 PM
April 12th, 2011, 09:09 PM
I'm going to highjack this old thread. Just attempted my first valve adjustment, and now the valves are rattling like crazy. Obviously I didn't do something right. So before I continue I want to be sure I'm using the right feeler gauge. Does this one look right for the intake?
It reads:
.004
.102
mm
I just want to be sure I'm reading it correctly...
April 12th, 2011, 10:10 PM
Attachment 3150
It reads:
.004
.102
mm
That's a good one. Do this though just to make sure you are on the right stroke. With the cover off the intake turn the engine over untill you see the valves push down, then by hand, keep rotating it until they come back up again or closed. Now with the sight port open rotate the engine another about half a turn until you see the timing mark show in the window and line up on the side detent/line. FT for the front and RT for the rear I believe. Then set your valves. Both the intakes and exhausts on that cylinder. Do the same for the other.
April 12th, 2011, 11:07 PM
Ok I tried again and got the rattling to stop, but now when I give it a little gas and let off, it drops rpm and stalls out. Does this mean the valves are too tight now?
April 13th, 2011, 12:19 AM
Oh maybe...When you set a valve, first it has to be dead cold so not run for around 4-6 hours. Next, you want a certian feel...friction level from the contact between the valve and the rocker on the feeler guage. If you can imagine the guage is paper, sliding it out should feel like it will almost tear that paper...almost.
Try this. Reposition the cam as I outlined before. Back off the lock nut and back off the adjuster a turn or two. Then slide your feeler gauge in and with your fingers only, turn the adjuster down onto the gauge and snug it with your fingers only. See..you can not overtighten it with your fingers. Then spin the lock nut back down and while just holding the adjuster still...and don't move it at all, tighten the lock nut. That most often will give you the correct feel on the feeler gauge.
I have one that when I tighten the nut, it pulls up a bit on the threads in the rocker so it gets loose when I lock it down. That one I give a little extra twist with plyers before locking it down. Point being, what ever you have to do to make them correct, do. And its VERY important that both valves be set identical.
April 13th, 2011, 08:49 PM
 I appreciate the tips! All adjusted and put back together.
2010 grizzly 700 valve adjustment, 650 brute force valve adjustment marks, adjust valves on brute force 650, adjusting valves on brute force 650, adjusting valves on bruteforce, brute force 650 correct valve, brute force 650 valves too tight?, brute force valve clearance, brute force valves adjustment, grizzly 700 valve adjustment, how to adjust valves on 07 brute force 650, how to adjust valves on 650 bruteforce, mud lite 26-10-12, reading a feeler gauge, tips and tricks 09 brute force valve adjustment, valve adjust for brute force 750, valve adjustment on brute force 650, valve feeler gauge brute force, youtube setting valvels bruite force 750, youtube valve adjustment on a 750 brute force
