Old July 31st, 2010, 02:19 PM   #1
jamesblair26's Avatar
Default Old Problem Arises Again!
So, the last time I had the Brute out is suddenly went into a power loss sorta limp mode.. figured it was the belt as I'd had some hard riding on it and the deflection was wayyy off. That ended up ending my riding for the weekend. Went home and did some tune ups including a new belt with great deflection.. cleaning the inside of the cvt and replacing the old clutch case cover gasket. Fired up the quad and still the same problem... when it runs it can go 60km an hour at max on a straightaway and bogs out going up a hill. has severe loss of power and almost sounds like its spuddering a bit when its given alot of throttle. Any ideas? am gonna check the fuel lines, valves, diffs, switch the dyna cdi to the stock, clean the carb and check the jets.. anyone else have any ideas?
God Hates A Coward!
jamesblair26 is offline
Old August 1st, 2010, 11:47 AM   #2
gusmx5's Avatar
Maby the fuel pump is dirty?Did you check it and clean it?Had the same problem and my brute was dying when i was giving full throttle to it....i took it out,cleaned and i was good as new...which model is yours?I am talking about 2008 and up.The pump is in the tank.
gusmx5 is online now
Old August 2nd, 2010, 12:13 PM   #3
mines the 06, just messed around with the carb cleanin and resealing and all.. seems to work aok now. noticed one of the flutter valves inside the carb wasnt moving, was a dead giveaway after that.
God Hates A Coward!
Old August 2nd, 2010, 02:16 PM   #4
throw a new set of plugs in it too..cant hurt, and they are only 2 bucks a pop
Old August 2nd, 2010, 03:01 PM   #5
which plugs are ya talkin about?
God Hates A Coward!
Old August 2nd, 2010, 04:43 PM   #6
Spark Plugs.. I do believe
