May 5th, 2010, 01:03 AM
front diff input shaft oil seal
who's replaced theirs? the micro fiche's online show tons of oil seals in the front diff. Mine is leaking where the input shaft goes in.
May 5th, 2010, 01:20 AM
ive replaced mine.. the big o ring one right?
May 5th, 2010, 01:22 AM
I guess so i havent taken anything apart. but its leaking from the input side of the front diff. just trying to figure out what part number I need. the micro fiches online list over 20 oil seals and my stupid computer wont show the image so i can reference to the part number
May 5th, 2010, 01:50 AM
SKU: 92049-1573
SEAL-OIL,TCY 48X65X8
is this the one your looking for?
May 5th, 2010, 01:54 AM
I dont know I cant see pictures online of the schematic that references the numbers to. probly have to go to my stealer and find out forsure. did you buy your seal local?
May 5th, 2010, 01:58 AM
yeah its like 8 bucks online so worst case 16 up here, and when i only need the odd rear seal or part under 50 i usually just goto the stealer ship. but if i am doing a bikebandit order or something i usually do a big order and order 4 or 5 rears.
bike bandits got the best shipping and price.. but use there own sku numbers
i got that sku off babbittsonline.com they use kawie sku numbers... but they have expensive shipping rates but the cheapest prices on parts.. its a trade off. but check out babbittsonline.com
also when you take yours apart i never did get an answer on this question if this SKU: 42034-1192
COUPLING,BEVEL should be loose mine wiggles back and forth a good 1/4 inch.... there is no bearing from what i can see that could go.. also the nut that holds it on from what i remember is a very very low torque setting.
May 5th, 2010, 02:25 AM
thanks busta i'll check into this tomorrow.
May 5th, 2010, 02:26 AM
international motorsports in delta has an online parts fiche now too, their prices are really good
www.internationalmotorsports.com
May 5th, 2010, 02:56 AM
wow there site has come A LONG WAY!!! i bought my brute off of them.. so its about 9 bucks for that seal usa and 12 up here... NOT BAD....see its easy for me cuz i get my stuff shipped to a reciver just across the border and drive the 15 min to pick it up... for you i wonder what the shipping is at IMS
BEN
May 5th, 2010, 10:05 AM
I was looking at the breakdown the other day to get it figured out and it looks like the coupling slides over the pinion shaft and is held in place with that nut but it has to rotate on the pinion when free-wheeling. The collor the actuator slides up the splines and the dogs it has on the end slide into the holes in the end of that coupling locking it to the shaft for 4wd. I don't see a bearing relating to it at the pinion but it has to have something so I would think it realy shouldn't have any noticeable movement on the pinion because of alignment issues it would have with the dogs on the collor...let alone seal leaking issues. If it were me, I would pull it and see if there is at least a brass sleave in there that needs replaced. JMO
42034-1192, front diff leak input shaft jeep, front diff leaking brute, front differential seal 750 brute, ktm 250 sx front shaft oil seal, oil seal at the impust shaft, torque tube sprocket 12586 refg, what oil goes in the front diff of a brute
