Old May 4th, 2010, 10:22 PM   #1
bruteboy's Avatar
Default ajusting carbs???
how can i tell when my carb adjustment is right? i put wat the kit recamended with a after market exaust and i have a slip on hmf.
right now it smokes black and feels like it is boggin down a lil bit. just want to know how to get my adjustment right thanks guy.
bruteboy is offline
Old May 4th, 2010, 10:47 PM   #2
Well it sounds rich. How about you tell us what main jets it had...and what thay had you put in. Did you change the pilots? Did you use a carb kit like a DJ? Does it smoke black over 1600 rpm or under? When it feels like its bogging, about what throttle position? 1/4,1/2, above 1/2...and so on.
Old May 5th, 2010, 10:56 AM   #3
bruteboy's Avatar
im not sure what was in like stock jets like 150 or so i put 165 rear i think 160 front and it smoke black higher rpms and when it bogs down its about half throtle
bruteboy is offline
Old May 5th, 2010, 11:18 AM   #4
That's a big jump. Grab the old jets, see what size they were, go up only one size....maybe.. Are the 160 and 165 a Keihin size and Dynojet size. Thay are different. There is a jet chart in Brute tec to compare.
Old May 5th, 2010, 11:20 AM   #5
bruteboy's Avatar
dyno jet size. i will look at diffrence in the jet sizes today when i get off work
bruteboy is offline
Old May 5th, 2010, 01:03 PM   #6
bruteboy's Avatar
ok i have 150 rear and 144 front still dont know wat size jets the stockers are tho i will have to try to find out
bruteboy is offline
Old May 5th, 2010, 01:50 PM   #7
how did you get 89hp on a dyno having the carbs not set properly?
Old May 5th, 2010, 04:02 PM   #8
bruteboy's Avatar
stock pipe and stock jets. setup stock never messed with the carbs untill i dynoed first i knew it was going to be a pain.
bruteboy is offline
