May 4th, 2010, 06:42 PM
Brute Engine Mounting Bolts Get Loose!!
On my last ride something happened that cause the shifter to vibrate and become out of align with the detents. I pulled the plastic and adjusted the linkage but it didn't make any difference in the way the shifter felt. I thought I either damaged the transmission or the engine had changed possitions (cracked frame or mounting bolt problem) and was going to check out today when I was changing some grease fittings and servicing the driveline.
Pulled the rear tires and took a look on the left side and my jaw hit the floor.
The rear engine mounting bolt had come loose and slid all the way out enough to about hit the floor board on that side. So I pulled the floor board, slid the bold the rest of the way out, cleaned and repaired the threads, put a little loctight on it and with the help of my trusty tire-iron providing a little engine lift, got it back in and torked it to..well..5 lbs over what the book calls for..to 51flbs. The bracket bolts were loose too. They got a little extra torked too!
The front bolt was still tight but it too got a little extra.
Sooooo...they do come loose guys. Better check yours. I think Gus..or someone.. had a post on this a while back.
Now I gota put the linkage back to where it was..plastics off again...Oh well.
May 4th, 2010, 08:27 PM
Roger that. Lots of guys have exhaust problems due to engine bolts comming loose. I checked mine while i was doing an oil change today and they were still good
May 5th, 2010, 08:00 AM
i have never checked mine and i should be the first to check them with all that vibrations...will do asap....
May 6th, 2010, 03:29 AM
This is a great tip and always overlooked.
Shift-linkage noise on the Brutes and Prairies is 99% of the time just loose engine mounts.
EAGLE EYE HID's
VHOLDR 1080P Helmet Cam
Ramsey 2500# Wireless Winch
Ricochet Belly Plates
CHUCK750 HDPE footwell Skids
API a/arm Guards
Powermadd Handguards
EHS Mudder Lid
UNI Air Filter
PBR Diff Lock Button
AMStar MX-Pro Tie Rods/Ends
Trail Tech Voyager GPS unit
May 6th, 2010, 04:18 AM
so what your saying is i should really get me A$$ in gear and check them...
May 6th, 2010, 09:32 AM
Yes, easy enough to do from the left side. You can get to the bolt heads to check them. The rears have extra extention brackets that have two bolts each too. Any of these loose or partly out like mine was can also make seals go out faster too.....
From what I have been reading here and other places, this happens more often then one would think. And it seems to be the rear mount bolt every time.
May 6th, 2010, 11:24 AM
Here's a thought, if they loosened up once, they'll probably do it again. Go to what ever hardware store around you that sells nuts/bolts and pick up enough nylon insert type lock nuts to replace the ones that have loosened up. Just my .02.
edit 1: That is of course there's a nut on those bolts to begin with.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
May 6th, 2010, 05:16 PM
Good idea. The rear one has a fixed nut, but the front doesn't.
May 6th, 2010, 09:11 PM
Locktite the front one! I'm checking mine tomorrow in the am...
bolts get loose, brute force 750 engine mount loose, brute force 750 motor mount problem, brute force 750 motor mounts, brute force broken motor mount, brute force front motor mount bolt, front motor bolt brute force, how does the mount for the engine get loose, loose mounted bolts, loose mounted bolts on board
