April 18th, 2010, 11:55 PM
'08 BF idle adjustment screw
Hey guys/gals. I need some help. I was stupid and thought the idle adjustment screw had something to do with turning the fuel on and off (same location as my old Fourtrax). I can't figure out where it screws back in. A pic or diagram would be nice. I've looked, and I can't seem to find it. The only diagram I have been able to find doesn't help either. Can someone help me out?
Reason: vocabulary
April 19th, 2010, 05:13 PM
actually figured it out...and i'm going to share it with a picture for anybody else with the same problem. i found a diagram of parts, and worked with it to show you what you need to know.
You want to take the left side plastic panel off (the side the screw is on). It's also a little easier if you take the exhaust cover off under that as well. In the picute, take the cover off of the compartment, and you will see a hole next to the drain tube. this is where you need to screw in the idle adjustment screw. we weren't sure if it had a spring or not, but we put one on just for fun. the picture should direct you in the right path.
April 19th, 2010, 05:43 PM
That's a carbed unit...05-07. You said an 08, which is fuel injected. Completely different.
April 19th, 2010, 06:37 PM
not too sure about that. mine's titled as an '08, and you can view the engine schematics for an '08 here: bikebandit.com/houseofmotorcycles/2008-kawasaki-motorcycle-kvf650f8f-brute-force-650-4x4i/o/m17990
i would link it if i was over 15 posts, but i'm not. maybe it's the 750 that's fuel injected.
if you also look at kawasaki's site, it will tell you that the 2008 Brute Force 650 is a carbed unit. it has a Keihin CVKR-34 x 2 carb. that info can be found here: kawasaki.com/products/product-specifications.aspx?id=247
Reason: additional information
April 19th, 2010, 06:42 PM
Oh...650...of course. The 750 is FI the 650 isn't.
April 19th, 2010, 08:21 PM
sorry. i should have specified. i have an '08 candy thunder blue BF 650 4x4i.
April 19th, 2010, 11:06 PM
Well, lets see a pic of your little baby?!?!
April 20th, 2010, 10:57 AM
don't have a great pic, but i'll post what i have.
April 20th, 2010, 12:44 PM
Nice! Looks like wheels and tires are in your future?
April 20th, 2010, 01:30 PM
i doubt it. i my be trading it this week for a 2006 Suzuki Boulevard M109R. i've been window shopping for this motorcycle for over a year. i had to throw in a trailer and a couple of rifles with it. only 2k miles on the bike.
Reason: spelling
08 brute force high idle, 2008 brute force carb drain screw location, 750 brute force idle adjustment picture, brute force 650 idle, brute force 650 idle air adjustment, brute force 650i idle adjustment, brute force 750 fuel injected idle adjustment, brute force idle screw not working, brute force throttle screw pictures, carb adjustment brute force 650i, fuel injected brute force idle adjustment, fuel injected brute force wont idle, how to adjust idle on 750 brute, how to adjust the idle on 08 brute force, how to adjust throttle 2010 brute force 750, how to fix idle on brute force 750i, idel adjustment screw for bruteforce 650i, idle adjustment picture on a brute force, kawasaki brute force 650 cold idle problems, throttle adjustment brute force
