Old April 11th, 2010, 09:49 PM   #1
The Great Pumpkin's Avatar
Default Idle Problem
Hello having a prob with the brute, 650, when she is running on a idle its missing and popping out of the carb when you add some choke and just it gas it seems to clear up ,, when your riding it seems ok notice it starting a bit a couple times but now it seems to be much more steady, i didnt know if it was dirt in a carb, the quad just hit 550 km just broke it in...
any ideas thanks Gino
The Great Pumpkin is offline
Old April 11th, 2010, 10:28 PM   #2
One very common problem is the carb boots. They split next to the clamps and suck in air. They also suck in dirt too! This make the mix lean and makes it pop back through the carb. Better check it. The other think is water in the bowls. Just drain them. Also, tight intake valves do that too.
Old April 11th, 2010, 10:54 PM   #3
ok thanks i will jhave to take a look i was thinking dirt from all the sitting,,i will have a good look this week and get it sorted out
Old September 25th, 2011, 09:50 PM   #4
mine is doing the same thing. just had the vaules adjusted by the dealer...it has no mods and 101 hrs and 177 mile....2006 brute force 750
foxhillbrute750 is offline
brute force 750i idle issue
brute force 750i not idiling
brute force idle problems
