April 11th, 2010, 01:32 AM
spring charts
Recently, I purchased big 27" swamp lites and have been looking at some of the spring charts, but I don't really know what I'm looking at. Currently, I have stock springs, but based on what I've been reading it looks like a EPI Maroon primary spring will give me the extra "umph" I'm looking to regain in the mud.
On the spring charts, what does the 2 1/2, 2 1/4, 1 1/4 mean?
Besides that, what do the numbers mean in those columns?
MudInMyBlood Forums Kawasaki Clutch Spring Chart
sorry if this is a newbie question....
April 11th, 2010, 09:52 AM
One of the only ways to make a chart on spring resistance is to level the playing field and put each in a press and squeeze them to specific distances apart and mark how much pressure it takes to bring them to these distances. You will see that at 2.25" the PSI or LBS is much less then say 1.5". The more you squeeze a spring, the more pressure it takes. MetalMan's spring chart shows the original or stock Brute spring pressures and both EPI & Dalton along with Primary and secondary springs. You probably would like the Maroon primary, and should have it. But if you are mudding, you will also want a little stouter secondary. With 27's, the red would be overkill so something less like Almond. If you didn't mud, then the stocks would still be OK.
April 11th, 2010, 09:20 PM
I got 27" swamps and maroon. love it... do a good bit of mud and everything else...
May 18th, 2010, 11:27 PM
Do you guys suggest doing a clutch kit over just doing springs? From the looks of a bunch of the signatures around, it looks like a lot are just doing the spring(s).
May 18th, 2010, 11:36 PM
The only other thing an EPI kit gives you is lighter flyweights...which wore out my pins so I put the stocks back in. And you can't pick your springs, so yes, just do the springs.
Now, for a few bucks more, there are other kits... like Dalton, which have adjustable flyweights, but I think you can do the same with spring pressures except ramping effects.
brute force maroon spring, brute force srpinr chart, brute spring
