Originally Posted by jackson
Does your brute have a noisey engine or does it run quiet? Im asking cuz I had mine rebuilt and it has a knock to it. I have heard the same thing on other brutes on youtube, but then on others I hear nothing and on those bikes seem to run stronger. My brute has power but falls on its face after 35mph. Could that noise be the timeing chain? It sputers a bit too about 1/4 throdle. If I am rideing slow when I hit 1/4 throdle it falls on its face too. Any advise?
BruteBoy's is all apart right now but on yours, Let me ask..
1. Do you have a Dynatek CDI?
2. If so,was anything done to the carbs before or after installation?
3. Are you sure the float levels are exactly where they should be?
4. Are you sure the valve lash is set correctly?
5. This knocking you hear, when do you hear it and does it go away at a certian RPM -if it does, what would you guess is that RPM?
Now let me ask a clutch spring question...because in and about 35mph is where the stock Brute seconday spring starts its final stage in shiftout and it does so quicker here then in the lower ranges. With stock tires you wouldn't notice it but with aftermarket tires, even just 26s on any aftermarket rims, the weight difference would make it feel like you need to grab a lower gear. It would still climb in speed but slower then with the stockers, and once you hit about 46-48 it would feel like it picked back up again in power some.
So, what tires and rims are you running and what springs are you running in the clutches?
