Old April 8th, 2010, 10:36 PM   #1
bruteboy's Avatar
Default crank
ok guys i just split my crank case today and pressed my crank out and i have a couple of ?s ok i put my new crank in the right side bearing to see if i needed a new one and it didnt have any side to side movement but it had a lil barley any at all up and down movement. it not the man ball bearing but the other bearing that the side of the crank with the teeth goes threw. and also wat does the jigs do when you press the crank back in to the case? and do you need them or can you make something that will do the same thing? thank guys
bruteboy is offline
Old April 9th, 2010, 01:20 AM   #2
bustamove's Avatar
i have never torn apart a brute.. but if you don't find what your looking for here i would higly recommend kawie riders, or highlifter.
bustamove is offline
Old April 9th, 2010, 09:26 AM   #3
x2. I have not had one apart or gone through the manual on the lower end either. I do know that egged bearings have to be replaced.
