March 26th, 2010, 02:02 AM
#11
Originally Posted by fastpapa
Do you guys run without the sreen mesh in the box and just run the air filter
I do. I think many around here do too. As long as you don't get any poping back through the carbs, you should be Ok. Flow is increased without it.
March 26th, 2010, 02:54 AM
#12
no screen in mine
March 26th, 2010, 04:05 AM
#13
air filter screen
Good to know. I am going to put the twin air filter in seems to be the best
09 750/ 880 fundy kit camo brute
27.5 growlers
12" itp wheels
warn 2500 winch
muzzy pro
msd
700 efi sportsman sold
March 26th, 2010, 12:28 PM
#14
Location: Live And Work In Montreal Que. From The Gaspe Coast , Port-Daniel
SCREENLESS!!!!
March 28th, 2010, 09:50 PM
#15
You are talking about the thin metal plate that covers the throats to the carbs? Yes, I pulled that out also! No screen plate. That much less air restriction.
March 29th, 2010, 03:53 AM
#16
im running a twin air replacement filter ... if you running K&N a pre filter IS A MUST!!!!!. if you don't they will suck dust in.
i don't know if i have any power gains due to my 2 inch snorkle
March 29th, 2010, 03:49 PM
#17
2" snorkle on mine sucked the power out of it. very very restrictive!
March 29th, 2010, 04:46 PM
#18
Yes it would, and for us carbed guys, it means a jet change. Do a 3"...and you won't notice anything. The outlet is about 2.25 so a 2" alone is downsizing, then add 90s and man..you are choking. The 2.25 pipe is fine until you add 90s. The 2.5" probably be fine but close if not a little restrictive at WOT.
April 8th, 2010, 02:56 PM
#19
K&N is a great filter for RACING only! When you need the most air flow..
TwinAir are cheaper and work great for any application where racing to win is not the primary objective.
Keep your stock or TwinAir clean at all times.. Also make sure you let your newly oiled filter sit in open air for a day before you run your machine, you have to let the carrier agent(the chemical used to keep the oil thin so you can apply it on the foam) time to evaporate or your machine will run very poorly..
