Old March 11th, 2010, 10:44 PM   #1
bustamove's Avatar
Default cracked/broke my exhaust
this would be the second time i have blown or cracked a hole thru the pipe right after the header. This time i decided to make a sleeve to fit over the pipe to add some extra metal to those thin pipes. its doesn't look the greatest, but hopefully it will get the job done.
bustamove is offline
Old March 12th, 2010, 12:18 PM   #2
Thom's Avatar
Hey does not look bad at all. nice work
Thom is offline
Old March 12th, 2010, 10:16 PM   #3
Got a little STEEL on it now.. Looks pretty good.
Old March 13th, 2010, 12:15 AM   #4
is this the factory exhaust?
Old March 13th, 2010, 01:17 AM   #5
bustamove's Avatar
yeah it is factory.... i can't afford to buy aftermarket for now(plus i like the stock db) those welds suck . i ran out of gas and had to swap FCAW in.
Old March 13th, 2010, 05:32 AM   #6
gusmx5's Avatar
This is the rear header right?Mine cracks at the front all the time...and once the back and i put the hmf slip on....
gusmx5 is online now
Old March 13th, 2010, 03:08 PM   #7
bustamove's Avatar
yes this is the rear header.. i checked quickly for cracks at the front.. but i didn't see any... which cylinder runs rich back or front i can't remember?
Old March 14th, 2010, 03:31 AM   #8
Hey guys, check your motor mounts. this happened to me once and it was bacause the motor was moving when under excellaration and being that the exaust bolts on to the motor, somethingh has to give. The two main motor mounts are notorious for coming slightly loose and eventually making the round holes oval.
boxer is offline
Old March 14th, 2010, 04:25 AM   #9
bustamove's Avatar
so just tighten then up and put some thread locker on there?
Old March 14th, 2010, 12:33 PM   #10
I realize how to fix the problem, i am just telling you why your pipes are cracking.
boxer is offline
muffler broke on brute force
