Old March 7th, 2010, 07:36 PM   #1
bruteboy's Avatar
Default aftermarket parts
does anyone no a website with aftermarket parts for the 07 brute i cant find one for nothing just oem parts??
bruteboy is offline
Old March 7th, 2010, 08:55 PM   #2
l Like what kind of parts? BikeBandit, Babbitts has some. RockymountainATV has some,
Old March 7th, 2010, 10:16 PM   #3
bruteboy's Avatar
see i looked on all of those an my brute is the kvf750b7f and they dont have the crank or pistions set for it and i need a crank and piston set to fix mine im just seeing if aftermarket would be cheaper that oem?
bruteboy is offline
Old March 8th, 2010, 12:46 AM   #4
Odd, found the KVF750b7f on Babbitts. All the parts are there.
Old March 8th, 2010, 12:50 AM   #5
OEM Parts Kawasaki Brute Force 750 4x4i (KVF750-D8F) 2008 CYLINDER/PISTON(S) - Cheap Cycle Parts
kawasaki part number for a 750 crank 13031-0079 296$
piston part number 13001-0021 69 dollars each.
Old March 8th, 2010, 09:22 AM   #6
Hmm..the "b7f" is an 07. Are they the same parts as the 08s?
Old March 8th, 2010, 10:59 AM   #7
bruteboy's Avatar
um are they aftermaeket tho? i dont want oem i was lookin for high compression pistions with some kind of aftermarket crank if they have them how do you get to them
bruteboy is offline
Old March 8th, 2010, 11:50 AM   #8
For pistons, you should be able to find hi-comp versions, try Wiseco. Now, you are probably stuck with an OEM crank unless you get a big bore kit. I'm almost certain that if a stock stroked aftermarket crank does exist, you'll be pay more for it than an OEM crank. Really, there's nothing wrong with the OEM cranks, just keep them oiled and they'll perform fine.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
richracer1 is offline
Old March 8th, 2010, 02:01 PM   #9
bruteboy's Avatar
i cant find any high compression pistons for the brute just forgded pistons if yal find any let me know please thakns
bruteboy is offline
Old March 8th, 2010, 04:54 PM   #10
crank part numbers all all the same from 05-2010. all the b7f means is his is camo hardwoods green. mine is a c7f which ment it was candy thunder blue.
BRUTEBOY I gave you links before in one of your other threads of companys that will supply you with aftermarket pistons and cams. four stroke tech, fundy performance, muzzys. im pretty sure the only aftermarket cranks you will find will be for the big 880-1000 stroker kits.
I would stay with stock crank and rods myself.
750 brute force aftermarket parts
aftermarket brute force crank shaft
aftermarket brute force crankshaft
aftermarket brute force fairings
aftermarket brute force piston
brute 2 brute 2 parts
