Originally Posted by joe man
I have a 2008 750 efi it is bone stock with 108 hours and 1200 miles. It ran great yesterday and I have never had any problems with I live in Michigan and it is snowy and about 32 degrees around here. today I take it out and poof it start and idles fine its also snappy if you rap the throttle buttttttt if you hold it wide open it just don't get there it pops and sputters about mid rpm same when you ride it any suggestions
Some folks have reported that in the freezing temps, moisture in the tank or fuel system freezes and cuts part or all the fuel supply off making it run kinda like you way. If you can put it in a heated area for a few hours and add some fuel de-ice, shake it up and run it a while in that heated area, it should fix that if that was the problem. Others are saying the boots between the injector bodies and the heads have cracked in the extream cold letting straight air in. Spray some starting fluid or carb cleaner on them while running to see if the RPMs increase. If so, there is a crack or split.
Also, check to make sure snow from the previous day's ride has not packed up against the front of the air box.
