Get BC Swag
Forum Members: 3,829
Total Threads: 4,751
Brute Central Forums » Brute Forums » Brute Engine & Drivetrain » Coolant what do you sugest
Old February 1st, 2010, 10:46 PM   #1
wildrunner's Avatar
Default Coolant what do you sugest
07 with almost 5000 kms and 465 hours should I change it or leave it alone/ Kaw. recomends changing every two years. Still looks clean to me.
2007 candythunder blue 750
dyna tech cdi / jet kit / k&n air filter with outter wear / super trap mud slinger exhaust /aluminum products full skid plates / kimpex front and rear bumpers / rear fender guards / quadrax 1.5 lift kit / fully snorkled and vent lines to pod /water temp gauge / skull shifter / 30 inch mud lites on itp type 7 rims / 27 inch big horns on itp ss 108 rims / kawasaki head light guards / shock covers / home made floorboard protectors / home made rad protector / reverse light
wildrunner is online now
Old February 2nd, 2010, 12:12 AM   #2
Change it. Even if it looks clean, some of the protectant additives it needs for aluminum engine use gets weak over time. Once the inside of the water jacket gets a layer of corrosion, it can't transfer heat as well. And the water pump and seals needs certain additives to be strong too. I just used prestone. There is some drains in different places on the block and to get all the old stuff out, you have to open them up. The manual shows you where they are.
06 Brute Force 750
26" BajaCross on 14"SS112s | Dynojet Stage1 | Dynatek CDI | Twin Air Filter | TPI Adjustable Airbox Valves | YFZ Catch Can Mod | Precision Pro Series Stabilizer | Perma-Cool Oil Cooler | Diamond "G" Tie Rods & Ends | EPI Maroon Primary W/Dalton Violet Secondary Springs & EPI X Belt | PowerMadd Handguards & Mirrors | Energy Swaybar Bushings | Full Set Ricochet Skid Plates | Highlifter Mill Finish Front Bumper | Warn 2.5 Wench | Tamarac & Kimpex Trunks | Rotopax
Old February 6th, 2010, 12:54 AM   #3
Do it and do your brute a favour and put Engine Ice in it.
'08 Brute Force 650i, 27" Swamp Lites, Mud Lid, 2500lb Warn Winch, Kimpex box
hayneser75 is offline
Old February 6th, 2010, 12:32 PM   #4
Does anyone know how much is needed to fill our 750 Brute"s?
richracer1 is online now
Old February 6th, 2010, 01:23 PM   #5
2.2 Litres
Bookmarks
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
