Old May 30th, 2009, 01:10 PM   #1
im getting a kind of loose rattling noise from my clutch just in idle though. when i give it a pop of gas and the belt engages it goes away.
i inspected the spider and the little rolers or bushings that rub up agoinst the clutch weights have a little bit of play from side to side. is this normal? theres like 2-3 mm each side of bushing of play.
thanks guys
05 Brute 750: 11:5:1 JE PISTONS, WEBB CAMS, FULL MUZZY, VFJ STAGE 3 Clutch, 2" LIFT, COPPERHEAD, CENTRE SNORKLES, K&N, DYNO JET and DYNO TUNED. 2009 SUNBEAM RED PLASTICS. 28" ZILLAS, STAINLESS STEEL BRAKE LINES
BRICKLAYER is offline
Old May 30th, 2009, 01:46 PM   #2
<div class='quotetop'>QUOTE (BRICKLAYER @ May 30 2009, 10:10 AM) <{POST_SNAPBACK}></div>
thanks guys[/b]
Not sure, but have heard of the spider assembly wearing to the point of having to be replaced. I assume those bushings are what wares on those. When not bearing pressure.. like at idle, I would think that could rattle. I wonder if we should be servicing those some how. I see on Babbitts that sell the whole spider assembly.
Old May 30th, 2009, 05:54 PM   #3
call vforcejohn maybe he can repair your old one or point you in the right direction
ss atv bushings primetime Brute Chassis & Electrical 2 April 2nd, 2009 11:14 AM
REVIEW:VFORCEJOHN STAGE 3 SPIDER MOD VTprairie Reviews 23 August 29th, 2008 08:13 AM
loose lug bolts lcerbone Brute Tire & Wheel Combos 3 May 31st, 2008 04:14 PM
Loose Belt? RainyCreekRider Brute Engine & Drivetrain 2 September 10th, 2007 09:44 PM
brute steering loose chapman06 Brute Tire & Wheel Combos 6 June 27th, 2007 10:46 PM
