May 28th, 2009, 12:11 AM
lol yes i know this doesn't really belong in this forum, but has anyone rigged up there quad to shoot flames out the exhuast? its more of a show thing then anything performance.
i did one to my truck, i just have a switch that when the truck is running i hit it and it turns off the spark plugs to the engine and raw gas goes thru the exhaust and there is a spark plug in the tail pipe and ignites the raw gass shooting flames.
now the only thing i would be scared of doing is blowing up the stock exhaust can.
can you tell im a little bored waiting for parts for the brute???
May 28th, 2009, 12:29 PM
this is extremly hard on engines, when you run raw fuel threw it, it washes the oil off the cylinder walls and pistons. last thing you will want to do is rig this up, and show your buddys up in the bush and start a fire or something.
May 28th, 2009, 01:52 PM
Isn't that just injected with a small pump or under air pressure directly into the exhaust system...not through the engine?
May 28th, 2009, 03:02 PM
some of the kits do exactly what bustamove is saying. flip a switch, shut the spark off to the engine, let the fuel pass threw the exhaust valve and load up in the pipe, then POOF
May 28th, 2009, 05:14 PM
<div class='quotetop'>QUOTE (BrianMc @ May 28 2009, 12:02 PM) <{POST_SNAPBACK}></div>
some of the kits do exactly what bustamove is saying. flip a switch, shut the spark off to the engine, let the fuel pass threw the exhaust valve and load up in the pipe, then POOF[/b]
Wow...seems like that would be a little hard on things...Poof?...more like BANG!
May 31st, 2009, 08:39 PM
<div class='quotetop'>QUOTE (BrianMc @ May 28 2009, 08:29 AM) <{POST_SNAPBACK}></div>
this is extremly hard on engines, when you run raw fuel threw it, it washes the oil off the cylinder walls and pistons. last thing you will want to do is rig this up, and show your buddys up in the bush and start a fire or something.[/b]
yes very true. yea it was kind of a spur of the moment post. i would defiantly not do it while out in the bush ESPECIALLY during the summer.
June 1st, 2009, 08:12 AM
<div class='quotetop'>QUOTE (bustamove @ May 31 2009, 05:39 PM) <{POST_SNAPBACK}></div>
yes very true. yea it was kind of a spur of the moment post. i would defiantly not do it while out in the bush ESPECIALLY during the summer.[/b]
Funny...many years ago, Kawie made a bike called the Bushwacker 175. We could call yours " BushBurner 750." Brings a whole new meaning to.."Smok'n your Competation"
June 1st, 2009, 04:25 PM
LOL he can call his the bushburner 750, and I call mine the racksmacker 750, now all the rest of you need some clever names for your quads
June 1st, 2009, 05:15 PM
I got a good one for mine...
AHEM..
2004 General Lee kfx700...12 hole airbox, 185/188 jets (3200'), cut springs, polished slides, mini MS mod, shimmed needles, coolant lines removed, DMC duals (need new set o' pipes), 6* key, O/BL spring, HR shorty shifter, ODI grips, Lowering Kit, 24" Extremes, fan switch, DG Fat series nerfs, Armadillo black bumper & Pro Armor shiney bumper, Pro Armor grab bar, Dixie Horn(MINE) What should I get next?...
2004 PINK kfx700...stock with some wierd nerf bars that came on it (WIFES)
June 1st, 2009, 06:56 PM
<div class='quotetop'>QUOTE (TrAnScEnDeNt @ Jun 1 2009, 04:15 PM) <{POST_SNAPBACK}></div>
I got a good one for mine... [/b]
yes you do!
