Old May 20th, 2009, 01:28 PM   #1
Kman's Avatar
Stupid question but does anybody know if there is a drain on the CVT?
Brute Force 650
Alum Skid Plates
Moose Hand Guards
Kenda Bear Claws
Kman is offline
Old May 20th, 2009, 02:12 PM   #2
<div class='quotetop'>QUOTE (Kman @ May 20 2009, 10:28 AM) <{POST_SNAPBACK}></div>
Stupid question but does anybody know if there is a drain on the CVT?[/b]
Should be. Look under the "Fat" front section. Its like a rubber plug with a wing grip I believe.
Old May 20th, 2009, 02:34 PM   #3
his is a sra it may be diffrent then the 750i but if it there it will be under the FAT section as pointed out. Just pull it out then reinsert it
Old May 20th, 2009, 03:28 PM   #4
Thom's Avatar
glad this came up on a side note. I hate the rubber plug. my seems to leak when under water. On my artic cat it was an actual screw with a rubber gasket. Seemed to work much better. Any one else have this issue? It does not leak a whole lot but enough to get water on the belt at times.
Thom is offline
Old May 20th, 2009, 04:35 PM   #5
<div class='quotetop'>QUOTE (Thom @ May 20 2009, 12:28 PM) <{POST_SNAPBACK}></div>
glad this came up on a side note. I hate the rubber plug. my seems to leak when under water. On my artic cat it was an actual screw with a rubber gasket. Seemed to work much better. Any one else have this issue? It does not leak a whole lot but enough to get water on the belt at times.[/b]
I don't have that problem...but I also don't have any water up here either LOL. I think I read somewhere that someone had modified one of those twist-lock plugs to work...you know the kind that you can insert, then screw in the lever-top, then flip over. Make a small one of these.
[attachment=2064:snap.jpg]
Or one of these
[attachment=2065:turn.jpg]
Old May 20th, 2009, 05:42 PM   #6
oldmanbrute's Avatar
my brother has an 06 650...it did not have a plug.
08 750BF, Team Green, 27" Bi/Tri Claws, EPI Maroon Primary Spring, EHS Mud Lid...... so far.
oldmanbrute is offline
Old May 27th, 2009, 03:42 PM   #7
Kman's Avatar
So I had a pretty good look around the CVT and I can't find the drain. All the cover bolts are visible so I guess if it swamps the cover has to come off. I thought things like this only happened to polaris's...
Brute Force 650
Alum Skid Plates
Moose Hand Guards
Kenda Bear Claws
Kman is offline
Old May 29th, 2009, 10:31 PM   #8
jhaynes75's Avatar
<div class='quotetop'>QUOTE (Kman @ May 27 2009, 02:42 PM) <{POST_SNAPBACK}></div>
So I had a pretty good look around the CVT and I can't find the drain. All the cover bolts are visible so I guess if it swamps the cover has to come off. I thought things like this only happened to polaris's...[/b]
My '08 650i has a drain plug (rubber). It's always under water/mud and not a problem. I only get water in my CVT when my CVT exhaust is under water.
'08 Brute Force 650 4x4i, Executioners, Kimpex Cargo Box, 2500 Warn Winch, Aluminum skid plate (custom), EHS Racing Mud Lid
jhaynes75 is offline
Old May 30th, 2009, 06:02 PM   #9
the sra is different then the IRS the sra and p650 has no drain hole
Old June 1st, 2009, 10:12 PM   #10
Kman's Avatar
<div class='quotetop'>QUOTE (RPM @ May 31 2009, 01:34 PM) <{POST_SNAPBACK}></div>
Nothing a drill and a plug won't fix.
You can also buy a newer CVT cover + plug and just replace the old one. They aren't that expensive.[/b]
When you say buy a newer one, do you mean for a 650i/750? Or am I just as well doing a little drill job? I'm not losing sleep over this, but... now that I talked about it the CVT will get flooded for sure.
Brute Force 650
Alum Skid Plates
Moose Hand Guards
Kenda Bear Claws
Kman is offline
2008 arctic cat cvt drain plug stripped
brute force 650 cvt drain
brute force cvt drain plug
draining cvt on a brute force
where is the cvt drain plug on a 2011 brute force
Stripped my engine oil drain plug! GatorTom Brute Engine & Drivetrain 10 August 16th, 2009 11:35 PM
Drain Plug for Coolant??? Bootlegger Brute Engine & Drivetrain 1 August 6th, 2008 01:24 AM
How to drain antifreeze ACEROCKS Brute Engine & Drivetrain 4 July 7th, 2008 11:37 PM
Diff drain plug johnny010 Brute Engine & Drivetrain 27 February 19th, 2008 06:20 AM
Oil drain plug englishmand Brute Engine & Drivetrain 2 August 4th, 2007 10:20 PM
