May 13th, 2009, 10:58 PM
Just trying to replace my primary spring without taking it to shop.
What is a good way to hold the primary clutch when torquing the 18mm bolt to 69 ft. lbs. with out buying the special tool.
Also any suggestions on how much torque required for removing bolt. Electric impact wrenches are 225 ft.lbs for cheap ones and 340 or so for 100 dollar impacts.
I read somewhere the cheaper units may not break the bolt.
Thanks
Brute Force 750, 11.5 pistons, trail/race cams, Elka PB36CR shocks, Programmable Dynatek cdi, Muzzy pro full exhaust, Diamond G tie rods and ends, diamond plate skid, custom over drive cut clutch, Dalton weights, comet black primary spring, HID lights,
Dakota tachometer, 27" Zillas, Precision stabilizer.
May 13th, 2009, 11:04 PM
take a long extension and go from the clutch down to the floor. I have used both impacts and worked great
May 13th, 2009, 11:10 PM
Thanks VT.
May 14th, 2009, 09:18 AM
And remember, that bolt is a left hand threaded and there are arrows on the clutch showing the direction to LOOSEN it. You don't need an impact to get it off. Its only 69-70 lbs to take it off too.
May 14th, 2009, 10:59 AM
<div class='quotetop'>QUOTE (BF Freak @ May 14 2009, 08:18 AM) <{POST_SNAPBACK}></div>
And remember, that bolt is a left hand threaded and there are arrows on the clutch showing the direction to LOOSEN it. You don't need an impact to get it off. Its only 69-70 lbs to take it off too.[/b]
much easier you don't need to brace it when you use an impact though
May 14th, 2009, 02:04 PM
<div class='quotetop'>QUOTE (VTprairie @ May 14 2009, 07:59 AM) <{POST_SNAPBACK}></div>
much easier you don't need to brace it when you use an impact though[/b]
Yup, just be sure to use the tork wrench to put it back on
May 14th, 2009, 03:34 PM
Thanks for the tips. I actually have done it once before when it was in the shop with their tools and everyone was busy. I just wasn't sure how to hold it when I torqued it with out that special tool. The Kawasaki mechanic said the 69 ft. lbs. was critical so don't just impact the bolt back on.
May 14th, 2009, 05:48 PM
<div class='quotetop'>QUOTE (Brutal rider @ May 14 2009, 12:34 PM) <{POST_SNAPBACK}></div>
Thanks for the tips. I actually have done it once before when it was in the shop with their tools and everyone was busy. I just wasn't sure how to hold it when I torqued it with out that special tool. The Kawasaki mechanic said the 69 ft. lbs. was critical so don't just impact the bolt back on.[/b]
He's right. I made a holder, but most just put a tire tool in there and let it bump up to the frame.
May 29th, 2009, 11:40 PM
I used a socket wrench and wedged it in and held it in my left hand and used the ratchet with my right. 69lbs doesnt seem very tight. I just switched hands putting it back on.
2009 Brute Force 750i, Green, Maroon Spring, Uni, Custom Snorkels, 25" Terracross XD's, Copperhead ECU,
May 30th, 2009, 01:27 AM
<div class='quotetop'>QUOTE (Bull750 @ May 29 2009, 08:40 PM) <{POST_SNAPBACK}></div>
I used a socket wrench and wedged it in and held it in my left hand and used the ratchet with my right. 69lbs doesnt seem very tight. I just switched hands putting it back on.[/b]
Well, that's what the book says. 69 foot pounds of tork is correct.
750 brute force clutch bolt torque, bolts the hold clutch on brute force 750, brute force 750 clutch bolt torque, brute force clutch torque, holding the primary brute cluch, how much foot pounds for a brute force 750 primary clutch, how much torque does primary clutch bolt on 750 brute force, how to torque primary clutch brute, kawasaki brute force 750 clutch bolt torque
