May 4th, 2009, 12:40 AM
what is the best spring to put on a 2005 750 brute force? i am getting ready for our local county fairs. i was told that i could change one spring instead of a clutch kit. i just want some real aggressiveness out of the hole. just going to do some roundtrack and about 200 feet of dirt drags. thanks for any help.
May 4th, 2009, 01:33 AM
<div class='quotetop'>QUOTE (bruteforceracer @ May 3 2009, 09:40 PM) <{POST_SNAPBACK}></div>
what is the best spring to put on a 2005 750 brute force? i am getting ready for our local county fairs. i was told that i could change one spring instead of a clutch kit. i just want some real aggressiveness out of the hole. just going to do some roundtrack and about 200 feet of dirt drags. thanks for any help.[/b]
I normaly would say the EPI Maroon, but for this event, maybe the EPI Red primary for an additional 300 rpm stall. A kit would be great for you though.
Just my 2 cents
May 4th, 2009, 08:52 AM
EPI maroon or if you want a little more stall and better snap go with Dalton O/B I liked the Dalton but can be hard to control on take off, the front end doesn't like to stay down. I found the Maroon pretty much covers all your bases and it works great on the trails as well.
May 4th, 2009, 09:09 PM
The only way to see the full benefit is to buy the cluth kit. For racing, highly recommend the dalton cluth kit. It is a bit pricey but worth it for the brute force. It will come with the orange/blue primary spring which controls stall and shift out rate. Make a wheelie bar for draggin. If you still have you factory wheel/tires, put them on. Put the bike in four wheel drive (on dirt track draggin) and dont let off. JMO.
May 4th, 2009, 09:31 PM
<div class='quotetop'>QUOTE (junglebuggy @ May 4 2009, 08:09 PM) <{POST_SNAPBACK}></div>
The only way to see the full benefit is to buy the cluth kit. For racing, highly recommend the dalton cluth kit. It is a bit pricey but worth it for the brute force. It will come with the orange/blue primary spring which controls stall and shift out rate. Make a wheelie bar for draggin. If you still have you factory wheel/tires, put them on. Put the bike in four wheel drive (on dirt track draggin) and dont let off. JMO.[/b]
I had the Dalton clutch kit it comes with the OB and weights all you need is the spring I tried drag racing with it but it was to hard to keep down. get both springs and try them out go with the one you like the best
May 4th, 2009, 11:38 PM
<div class='quotetop'>QUOTE (VTprairie @ May 4 2009, 08:31 PM) <{POST_SNAPBACK}></div>
I had the Dalton clutch kit it comes with the OB and weights all you need is the spring I tried drag racing with it but it was to hard to keep down. get both springs and try them out go with the one you like the best[/b]
i forgot to say that i already have a hmf qs1 eco-system pipe, k&n air filter, and a moose module and running itp holeshot atr on c-series wheels if that would make any difference. thanks again for any help.
May 5th, 2009, 08:42 AM
personally I would get the EPI maroon I run it and tried others I like it the best. Get the Vforcejohn stage 3 clutch mod and you will a big difference right there, best bang for the buck as far as I am concerned.
May 5th, 2009, 03:54 PM
<div class='quotetop'>QUOTE (VTprairie @ May 5 2009, 07:42 AM) <{POST_SNAPBACK}></div>
personally I would get the EPI maroon I run it and tried others I like it the best. Get the Vforcejohn stage 3 clutch mod and you will a big difference right there, best bang for the buck as far as I am concerned.[/b]
What would the maroon spring do to my stock 09 brute? I ordered it and plan to do the Vforcejohn clutch but I am going for a big ride this weekend and the spring will be in thursday so I may put it in if does any good.
2009 Brute Force 750i, Green, Maroon Spring, Uni, Custom Snorkels, 25" Terracross XD's, Copperhead ECU,
May 5th, 2009, 04:01 PM
<div class='quotetop'>QUOTE (Bull750 @ May 5 2009, 02:54 PM) <{POST_SNAPBACK}></div>
What would the maroon spring do to my stock 09 brute? I ordered it and plan to do the Vforcejohn clutch but I am going for a big ride this weekend and the spring will be in thursday so I may put it in if does any good.[/b]
you will be pleased it gives you more low end snap from the extra grab of the belt. Once you have the clutch mod done and the spring you will see a noticeable difference. Takes about 30 mins to change the spring no problem.
May 5th, 2009, 05:45 PM
I just did the EPI maroon primary last week! Was running the EPI pink before but like the maroon a lot better! That's what I would go with but your call.......
'06 Brute Force 650 4x4i
26" Maxxis Bighorns, 12" ITP SS 106,
Direction 2 Overfenders, Diamond Bumper,
Floor Board Trim, Engraved Billet Shifter,
Copperhead VDI, Full Muzzy Exhaust, DynoJet kit
Clutch Springs (EPI maroon primary, stock secondary)
Intake Splash Guard, Swaybar Removed....
brute force 750 spring color, brute force clutch spring color, primary spring color brute force 26 tire, what color spring for a brute force, what color what color spring brute force 30 tires
