May 26th, 2009, 11:44 PM
#11
THANKS GUYS FOR THE INFO. I HAD THE EPI MAROON PRIMARY INSTALLED ALONG WITH A NEW KAWI BELT. I TRIED IT OUT SUNDAY AND I AM VERY PLEASED WITH IT. MY FIRST RACE AT THE FAIR IS JUNE 5. I'LL LET YOU GUYS KNOW HOW IT GOES. THANKS AGAIN.
May 27th, 2009, 12:25 AM
#12
maroon spring works good for me also. althoiugh it seems to be tricky for me putting the quad in the back of the truck and creeping it forward, i usually smack the window eekkk
May 29th, 2009, 10:39 PM
#13
<div class='quotetop'>QUOTE (BrianMc @ May 26 2009, 11:25 PM) <{POST_SNAPBACK}></div>
maroon spring works good for me also. althoiugh it seems to be tricky for me putting the quad in the back of the truck and creeping it forward, i usually smack the window eekkk[/b]
All of my riding is on trails (a little bit on roads to get to the trail). The maroon spring is getting a lot of positive feedback. Would the maroon be a good fit on an '08 650i on 25" executioners?
'08 Brute Force 650 4x4i, Executioners, Kimpex Cargo Box, 2500 Warn Winch, Aluminum skid plate (custom), EHS Racing Mud Lid
May 29th, 2009, 11:36 PM
#14
I just got back from my first ride with the maroon spring and it is jumpy but I like it. Gives better low end and mid seems improved but may just be me.
2009 Brute Force 750i, Green, Maroon Spring, Uni, Custom Snorkels, 25" Terracross XD's, Copperhead ECU,
May 30th, 2009, 01:36 AM
#15
<div class='quotetop'>QUOTE (jhaynes75 @ May 29 2009, 07:39 PM) <{POST_SNAPBACK}></div>
All of my riding is on trails (a little bit on roads to get to the trail). The maroon spring is getting a lot of positive feedback. Would the maroon be a good fit on an '08 650i on 25" executioners?[/b]
If you tend to put the belt under heavier loads like riding in thick mud or steep hill climbing or drag racing or pulling trailers and others, then yes, the maroon is a good choice even with 25s. If you don't do these things, then its not necessary and would be a waste for you. Always remember to check and adjust the belt deflection when necessary. Lower deflection...that is closer to the 22mm mark will give you the least stall.
brute force 750 spring color, brute force clutch spring color, primary spring color brute force 26 tire, what color spring for a brute force, what color what color spring brute force 30 tires
