Old April 30th, 2009, 05:30 AM   #1
AKBill's Avatar
So I have been reading up on CDIs, Moose Modules, Highlifters unit mentioned in the title. My question is will these work on the 08 750i? Just looking to get a little more kick out of the launch.
Shut up and ride!
AKBill is offline
Old April 30th, 2009, 05:43 AM   #2
adamjamk's Avatar
No that will not work on your 08. It is for 05-07 models only.
06 brute/digital Oil Temp gauge/Shindy digital tac/NGK CR-1 plug wires/Pro Armor
27" MST,S/ITP SS112/High lifter front bumper/Twinair air filter
full MUZZY/Dynatek programmable ECU/Dynatek coils /American racing Tie rods heavy duty
Steering stabilizer Gibson/Energy sway bar bushings/CVT snorkeled /dynojet kit
Radiator high lifterTriple pass/Fan override switch /HL 2" LIFT KIT/
snorkeled air box/Elka shocks/Rox Riser kit/extreme trail tec bars
Wisco pistons 11.5.1/hot cams Stage one/Ported intake
/Epi primary spring maroon/EPI secandary black
adamjamk is offline
Old April 30th, 2009, 08:39 AM   #3
<div class='quotetop'>QUOTE (adamjamk @ Apr 30 2009, 04:43 AM) <{POST_SNAPBACK}></div>
No that will not work on your 08. It is for 05-07 models only.[/b]
ditto
Old April 30th, 2009, 09:46 AM   #4
<div class='quotetop'>QUOTE (VTprairie @ Apr 30 2009, 05:39 AM) <{POST_SNAPBACK}></div>
ditto[/b]
x2, but...wouldn't a programable EFI controler be a good thing to have here?
Old April 30th, 2009, 10:45 AM   #5
AKBill's Avatar
I'm seeing on other sites "not that it means it's true" that the 08 is de-tuned on the bottom end by retarding the timing like it's earlier versions. There are other riders actually installing the Highlifter Module on their 08's and claiming a degree of success. I was hoping the guy from Highlifter would chime in and shed some light on it one way or the other.
Shut up and ride!
AKBill is offline
Old April 30th, 2009, 12:40 PM   #6
yes this true but only with the 650 models the 750 is EFI and its different. The EFI gives power about the same as a carbed model with a dyna. I tried one out at the dealer and thats what I found
Old April 30th, 2009, 03:34 PM   #7
AKBill's Avatar
That is good to know. Thanks for the clarification VTprairie. So what are you guys running and how was the bang for the buck? EFI controller really make that much differance?
Shut up and ride!
AKBill is offline
Old April 30th, 2009, 03:42 PM   #8
AKBill I have to say I may be wrong I was over at HL and found this
HL link
check it out
Old April 30th, 2009, 04:17 PM   #9
MetalMan's Avatar
I have a 08 FI 750 brute. I have also installed one of the older model HL ICM Power Pak's. I have to say i did not notice a huge difference like some are calming. More like a small difference. To tell the truth its hard to feel it since the 08's launch so hard as it is but after i added it i run against my buddies brute which is a 08 FI 750 as well. I get him out of the hole every time now. After about 60 feet or so the margin stays the same or close. We have next to the same mods and tires.
Like i stated there was no night and day difference or should i say WOW factor with mine but it does make a small difference.
If you get one of the modules it will need to be the older solder in style. The newer ones with the plugs will not work because the FI bikes have the wires run to a different spot on the ECM.
I posted pics in this thread showing how to wire it up.If you have any questions just ask. I'll help if i can.
http://www.mudinmyblood.net/forum/showthre...=741&page=2
08 750 FI Brute Force Team Green
VFJ Stage 3 Spider Mod
VDI CopperHead
HMF Swamp Series XL
Snorkels with 2 1/2 air intake (mudinmyblood.com)
28" Zillas ITP SS 112's
6K H.I.D Head Lights
MetalMan is offline
Old April 30th, 2009, 09:10 PM   #10
AKBill's Avatar
Thats the same things I have been reading the past few days VTpraire. Appreciate you looking a little further into it. Thanks for the install info MetalMan, always good to know someone with first hand experiance.
You know I think I'm going to give it a whirl. There are a couple of choices out there so not sure what one to try. Kind of leaning towards Diamond G Racing's module. Seems to go a bit further then the rest. Havent talked to them yet though. Will tomorrow and let know what he has to say.
Thanks for the replys guys.
Here's a couple of links to the before and after vids on you tube. Seen these on MIMB site.
Stock 750i
750i with Module
Shut up and ride!
AKBill is offline
high lifter ecm power pak
high lifter ecm power pak review
high lifter fan override
high lifter power pak brute force 650
highlifter ecm power pak
highlifter outlaw mst ss-112
highlifter pictures
how to wire up for ecm
HighLifter shock springs AKBrute Brute Chassis & Electrical 4 August 4th, 2008 11:16 PM
Highlifter springs BluelightSpecial Brute Chassis & Electrical 2 July 18th, 2007 10:41 PM
Highlifter Outlaw MST's Rock!!!!!!!! Mudcon Brute Tire & Wheel Combos 2 July 18th, 2007 01:03 PM
ICM power pack vrs DG5 power module bruteboy101 Brute Chassis & Electrical 1 June 29th, 2007 12:02 AM
New Highlifter 8in Lift superbogger750 Pictures & Videos 26 February 1st, 2007 01:01 AM
