Brute Central Forums » Brute Forums » Brute Engine & Drivetrain » Changing Secondary Clutch Spring
Old November 10th, 2008, 10:11 AM   #1
I am running an E.P.I. maroon primary and almond secondary and still having belt slipping issues. I was told that the almond secondary is not the correct spring to be running which may be why I am working on my third belt after just 300 or so miles. I also have had problems where when I get into something deep the belt slips so bad that the wheels aren't even turning. I am wanting to put 31" outlaws but want to fix the slipping issues first. I am hearing that for the 29.5s that I have or for the 31s I need to go with the yellow secondary spring. I lost about 8mph on top end speed with almond and was wondering what to expect with yellow.
Also if anyone has a secondary clutch compression tool to sell let me know.
2008 Team Green Brute Force 750:
SS 2" Lift, 1.5" Spacers, ITP SS112s, 29.5 Outlaws,
3000lb. Winch, HMF Swamp Series,
EPI Maroon/Lime Green, Center Snorkels,
Radiator Relocated
jaup09 is offline
Old November 10th, 2008, 10:15 AM   #2
Also I am curious if anyone knows if the Dayco HP drive belt are at least as good as the stock belts? I am wondering because I found a place that sells these and for a bit cheaper compared to the stock belt.
Radiator Relocated
jaup09 is offline
Old November 10th, 2008, 10:20 AM   #3
Jv2cat's Avatar
I would recomend the OEM (Stock) BF belt. Also the yellow secondary will help a lot with the slipping / smoking but you will have no top end whatsoever.
Jv2cat is offline
Old November 10th, 2008, 10:30 AM   #4
Jv2cat's Avatar
Here is a spring/tire chart that may come useful..
Maroon (Lighter than stock. Not the same as the maroon primary)
Black (Almost same as stock)
Almond( Good for 27'' and lighter 28'')
Green( Good for heavier 27'' and all 28" )
Lime green( Good for heavier 28'' and maybe 29.5")
Red (Perfect for 29.5'' and the lighter 30")
Blue ( Heavy 28" - 30")
Yellow ( Good on only 30'' or larger most aggressive tires)
Jv2cat is offline
Old November 10th, 2008, 01:56 PM   #5
Yeah I am going to try the Lime Green first and see what it does. I was able to find a spring compression tool. Thanks for all the help.
Radiator Relocated
jaup09 is offline
Old November 10th, 2008, 06:31 PM   #6
MetalMan's Avatar
Yeah i agree you need a stronger spring then the almond. Most i see posting on HL are running the red with the 29.5's and having good luck but your gonna lose some top end. Have you checked your defection to make sure its adjusted right?
Also if your slipping the belt that much your sheaves could be glazed over or even damaged. Next time your in there be sure to look them over really good for wear/groves. If thats the case no spring will fix it.
And I'm sure you do but it worth mentioning,always use, low gear for slow speeds and the mud.
08 750 FI Brute Force Team Green
VFJ Stage 3 Spider Mod
VDI CopperHead
HMF Swamp Series XL
Snorkels with 2 1/2 air intake (mudinmyblood.com)
28" Zillas ITP SS 112's
6K H.I.D Head Lights
MetalMan is offline
Old November 10th, 2008, 07:00 PM   #7
<div class='quotetop'>QUOTE (MetalMan @ Nov 10 2008, 04:31 PM) <{POST_SNAPBACK}></div>
And I'm sure you do but it worth mentioning,always use, low gear for slow speeds and the mud.[/b]
I talked to the EPI guy and we decided I would try the lime first and see what happens then work towards the yellow until we get the right combination. As far as the primary sheave goes it was scared pretty bad after the last belt that broke. Belt was in pieces. See picture below sorry for the poor quality it was a cell phone pic. Not sure what caused it to come apart in pieces. I was thinking maybe it was a bad belt.
[attachment=1234:1103081840a.jpg]
Radiator Relocated
jaup09 is offline
Old November 10th, 2008, 07:05 PM   #8
The above was a picture of the most recent broken belt. For whatever reason it was completely destroyed and in pieces. The first broken belt was nothing like that. See picture below.
[attachment=1235:belt.jpg]
Radiator Relocated
jaup09 is offline
Old November 10th, 2008, 08:37 PM   #9
Here's a pic of the one and only Dayco I ever bought...it lasted 20 miles. The OEMs are the best, although the EPI I have is lasting well.
http://i483.photobucket.com/albums/rr196/B...cs/DSC01070.jpg
If the shives are hurt, maybe its time for a...VFJ mod
Old November 11th, 2008, 11:38 AM   #10
20 miles wow that's not good. I guess I will stick with the stock belts.
Yeah I messaged VFJ yesterday before ordering new spring. I am going to put new spring in and I hope to get him to mod my clutch as well while its torn down.
Radiator Relocated
jaup09 is offline
2005 brute force 750 clutch
bad primary clutch on brute force 650
brute force 2005 secondary clutch problems
brute force 650 clutch springs
brute force 650 primary spring
brute force 650 secondary springs
brute force 650i clutch springs
brute force 750 changing secondary clutch spring
brute force before after clutch spring
brute force green secondary spring
brute force secondary problems
epi almond brute force
epi almond secondar d
oem clutch spring for a brute force 2005
quadboss primary spring
smoking belt after high lifter clutch kit
take apart brute force secondary
what does the secondary clutch brute force 750 do
where is the secondary clutch spring on a brute force 750
Secondary clutch spring compressor. shawn3806 Brute Technical Articles 22 August 20th, 2009 02:12 PM
Anyone have a link to a how to for secondary clutch spring? ojcool Brute Engine & Drivetrain 2 August 8th, 2008 11:19 PM
Secondary clutch spring mossy Brute Engine & Drivetrain 9 July 30th, 2008 08:35 PM
sound after changing the clutch spring? johnny010 Brute Engine & Drivetrain 7 February 19th, 2007 01:18 PM
Secondary clutch spring compressor. shawn3806 Brute Engine & Drivetrain 0 December 31st, 1969 08:00 PM
