Old October 12th, 2008, 08:06 PM   #1
07galaxy650's Avatar
Default Brute hard to start?
So every now and again, my brute is extremely touchy when starting it. I know i installed a pipe and cdi, which prolly dont help it. Is it because i need to rejet? B/c even when i use the choke it dont always work, usually just the gas and then pump it. If it has been warmed up, it will start fine most of the time. But not always. I have heard of people saying something about adjusting the valves and what not but dont know anything about it. What is some things or suggestions on how to fix it. Thanks.
07galaxy650 is offline
Old October 12th, 2008, 08:28 PM   #2
Default Re: Brute hard to start?
Well, these can be hard to start for several reasons.
The #1 reason is the valves are too tight and have not been adjusted in a long time. If left that way for too long, the seats burn and you will need a valve job.
The #2 reason is fuel related. Bad Gas, Bad fuel pump, plugged or cracked supply line, Plugged tank vent or cap, water in the gas tank and/or carb bowls, Float levels low...ect.
The #3 reason is electrical related. Bad plugs, bad CDI, weak coils, Rear Buss connecter problems...stuff like that.
The #4 reason is that the engine is just in need of a rebuild and the compression is just low enough to need help starting when cold, but has enough after warmed up to make it on its own...for a while. It should be going through oil in this state though.
Hope this helps.* Good luck 07galaxy650 .
Old October 12th, 2008, 08:39 PM   #3
my opinion is the valves
Old October 12th, 2008, 08:49 PM   #4
well i bought it brand new and now i have 96hrs on it. Never had a valve adjustment done on it. Is that the problem you think?
Old October 12th, 2008, 08:54 PM   #5
Here is the big problem. I am not a technician.lol. Seriously though, what and how do you do it. I have never fooled with doing this before, but nothing is very hard on these bikes. A little help will be appreciated.Thanks.
Old October 12th, 2008, 09:21 PM   #6
shawn3806's Avatar
Buy the factory service manual.* It lays it all out for you.
3000Lb Viper Winch.
Highlifter Radiator.
Highlifter Springs.
ASR X Series Tierods.
Rox Risers Solex Handlebar.
Drat Fab Lowering Kit.
VFJ Stage 3 Goodness.
EHS Airbox Lid.
Maroon Primary Spring.
</span></span></span>
shawn3806 is offline
Old October 12th, 2008, 09:41 PM   #7
yeah i have it. I will check that out. Thanks alot guys.
Old October 12th, 2008, 09:58 PM   #8
I was going to say if you don't have the manual, here's a link to a free 750 manual. the valve service is the same.
www.mmi.org/merrington/atv/files/bruteforceshopmanual.pdf.
On the other hand, it might be time for a visit to the service department. Not cheap, but sometimes worth it. A full "going-over" might be a good thing...if you trust your dealer....and you have a few extra bucks.*
Old October 12th, 2008, 10:43 PM   #9
Enigma- Yeah I am the same. When it comes to a vehicle, i got it covered. When it comes to these bikes, i am lost. The concept is the same, but i would rather ask some questions and know i am doing it right.
I wouldnt mind taking it to a dealer and having them go over everything, but I cant afford that right this moment. SO I am stuck doing it myself. Which i enjoy, but some stuff i need help or just assume ask you all b/c chances are you have done it and know some tips. Thanks both of you.
Old October 12th, 2008, 11:46 PM   #10
Any Time. Good luck
05 brute hard to start
2009 brute force hard starting
2009 kawasaki 750 brute force hard starting
2009 kawasaki brute force 750 oil light hard starting
brute force 750 hard starting
brute force 750 hard to start
brute force hard to start when warm forum
brute force hard to starting
brute force pri hard start
brute force storage mod
bruteforce pri hard to start
have a 2006 750 brute force hard to start when cold
how long do i leave brute force 650 on choke while starting?
kawasaki brute force 650 hard to start
kawasaki brute force 750 hard to start
kawasaki brute force 750 hard to start when hot
kawasaki brute force dynatek cdi and coil
o9 750 bruteforce hard to start
what makes a 750 brute force hardto start
what makes a brute force hard to start?
Hard Warm Start Issue! Wildman1988 Brute Engine & Drivetrain 11 May 24th, 2009 06:44 PM
o5 brute wont start yardbird Brute Engine & Drivetrain 3 April 25th, 2009 12:24 PM
hard start on bf650i 06bf650i Brute Engine & Drivetrain 1 September 4th, 2008 01:36 AM
Brute hard to steer billnz28 Brute Chassis & Electrical 1 April 8th, 2007 01:34 AM
Too much air = hard to start? machinewars Brute Engine & Drivetrain 9 March 11th, 2007 08:48 PM
