September 15th, 2008, 10:31 PM
750 brute force
Howdy i have a bad problem, i blowed my engine up on my brute force. :cuss: reason is a rear seal blowed out, i had no oil in the motor . i have heard of a 900 big bore kit ,so i thought if im going to have to spend money on the bottom end why not spend some on the top end . if someone could tell me where to get a 900 big bore kit or the biggest they make i would thank u alot.* :peace:
September 16th, 2008, 10:13 AM
Re: 750 brute force
There are a few people.* There is Mickey Dunlap as Four Stroke Tech, Flynt also builds motors and I believe VForce John does some engine work as well.* I can go ahead an tell you now that the 900 kit aint going to be trail friendly.* I would recommend an 840 with stage 2 cams and pistons.* I have a built 840 in my Brute as well.* You will be looking at about 2500 for parts and labor.* Could be plus or minus a few hundred depending on what you get.* You should have also posted this down in the Brute Engine section for future reference.
The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants - Thomas Jefferson
September 16th, 2008, 10:33 AM
Re: 750 brute force
I am going to move the post to the Brute Engine section, but also want to say that there are three major suppliers of kits, and they all make some nice power.* You can go with Fundy Motor Sports who built Camo's turbo charged monster.* AMR (After Midnight Racing) also has some very popular kits that are very fast, and of course Mickey at FST (Four Stroke Tech).* You could not go wrong with having VFORCEJOHN
do your build.* Flynt is also a stand up guy and did the valve work, and porting, on my Prairie.* Ray, at Fundy, will build the motors, but he seems to be swamped and his turn around time can be slow because of this, but quality work from everything I read.* Glen, at AMR, also has a great reputation, for his kits, his porting skills, and his engine work.* Give all of them a call and then make your choice...
September 17th, 2008, 02:02 AM
Re: 750 brute force
don't the brutes have oil lights. or was the damage too fast to stop?
October 2nd, 2008, 11:35 PM
Re: 750 brute force
i dont guess it ever worked ,but it did flash when u first turn the key on.<div class='quotetop'></div>
don't the brutes have oil lights. or was the damage too fast to stop?[/b]
07 brute force 900 kit, brute force 900 fst kit fuel, brute force engine flynt, built brute force engine, fst built brute
