Old September 3rd, 2008, 08:58 PM   #1
Default hard start on bf650i
i have been having a hard time starting when i let my bike sit overnight or over 4 hours. after i finally get it to start and run it for few minutes, it will crank on the first turnover. i have put new jets in when i put hmf on. but i was wondering if it could be the valves. engine runs great after you finally get it goin.
06bf650i is offline
Old September 4th, 2008, 01:36 AM   #2
TonyBlonie's Avatar
Default Re: hard start on bf650i
i have been having a hard time starting when i let my bike sit overnight or over 4 hours. after i finally get it to start and run it for few minutes, it will crank on the first turnover. i have put new jets in when i put hmf on. but i was wondering if it could be the valves. engine runs great after you finally get it goin.[/b]
My valves were too tight and caused hard starting at 1000 miles. It never hurts to check and adjust them.
I also have a weak fuel pump which is vacume operated on the 2006 650i. Try turning the fuel selector to prime next time before you start cranking. It gives a little more fuel pressure to the carbs.
These two things turned my almost impossible-to-start bike into a dependable ride.
TonyBlonie
2006 650i Brute Force: Dynatec CDI, Warn 2500XT, Fan bypass switch, swaybar removed,
2" DratFab lowering kit, Winch lockout switch, DC outlet on switch, Pink Primary, Almond Secondary,
Strobes, 60" Cycle Country snowplow, custom aluminum shift knob
TonyBlonie is offline
Hard Warm Start Issue! Wildman1988 Brute Engine & Drivetrain 11 May 24th, 2009 06:44 PM
Brute hard to start? 07galaxy650 Brute Engine & Drivetrain 9 October 12th, 2008 11:46 PM
my future BF650i scortadict Pictures & Videos 4 September 16th, 2007 12:57 PM
Too much air = hard to start? machinewars Brute Engine & Drivetrain 9 March 11th, 2007 08:48 PM
Very Impressed with my BF650i.. randyrw General Discussion 19 February 1st, 2007 04:51 AM
