Old July 27th, 2008, 03:15 PM   #1
mossy's Avatar
Default Secondary clutch spring
I am wanting to change secondary spring. I am running 27x10x12 fronts and 27x12x12 rears Silverbacks. I was told a lime green would be good, what do yall think?* BTW.....I have a '08 BF 750
'08 BF 750,ss112's,27"Silverbacks
ssatvplus 2" lift
maroon primary clutch spring
1.5" HL wheel spacers
HL Springs
mossy is offline
Old July 27th, 2008, 05:42 PM   #2
GatorTom's Avatar
Default Re: Secondary clutch spring
Depends on your riding style.* I'm running a maroon primary/almond secondary with 27" Swamplites.* Some folks say to just go with the maroon primary/stock secondary when running 27" tires and below.* What are you wanting to get by changing your springs?
GatorTom is offline
Old July 27th, 2008, 08:05 PM   #3
mossy's Avatar
more low end power! The silverbacks are pretty heavy.
ssatvplus 2" lift
HL Springs
mossy is offline
Old July 27th, 2008, 09:07 PM   #4
GatorTom's Avatar
I like the maroon/almond spring combo.* I lost a little power when I added bigger tires.* With this spring combo, my brute is back to the wheelie monster it was before.* ;D
GatorTom is offline
Old July 27th, 2008, 09:47 PM   #5
mossy's Avatar
But my tires are a little heavier then yours I think. Thats way some people said go with a stronger spring.
ssatvplus 2" lift
HL Springs
mossy is offline
Old July 27th, 2008, 10:16 PM   #6
I run 27 xtrs with stock secondary and maroon and don't have an issue it works great and I can wheelie all day long I didn't like the almond lost to much top end and I don't think the belt is any tighter then with I got with the stock spring. Its all in your prefrence get the springs try them and see what you like you can always unload the springs to someone on the sights. I don't think those tires are any heavier then the xtrs. get the springs give it a shot.
Old July 28th, 2008, 03:42 AM   #7
ThaMule's Avatar
I'm running a maroon primary/stock secondary with 27" MST's on beadlocks and I just leave it in there when i swap to my 29.5" laws and it still pulls good and I can ride wheelies all day long.*
The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants - Thomas Jefferson
ThaMule is offline
Old July 30th, 2008, 05:47 PM   #8
mossy's Avatar
I can ride wheelies also, but being 6'2" and 235lbs does not help.
I am going to try a secondary spring.........not sure which one though.
ssatvplus 2" lift
HL Springs
mossy is offline
Old July 30th, 2008, 07:20 PM   #9
GatorTom's Avatar
But my tires are a little heavier then yours I think. Thats way some people said go with a stronger spring.[/b]
The almond secondary is overkill for my size tires.* I'm going to remove it and put the stock back in the next time I do belt maintenance.* You would be fine with either the maroon primary/stock secondary or maroon primary/almond secondary.* IMO the lime green secondary is overkill.
GatorTom is offline
Old July 30th, 2008, 08:35 PM   #10
STOGI's Avatar
Yeah ... the backs are pretty heavy for 27's . Not only the weight but the strain of turning them in thick mud, climbing out of ruts* and the different things that put more strain on the bike than just riding down the trail is the reason a lime green is a good idea.
BF750 Built For Business
Stock is for pansies.
STOGI is online now
Secondary clutch spring compressor. shawn3806 Brute Technical Articles 22 August 20th, 2009 02:12 PM
Changing Secondary Clutch Spring jaup09 Brute Engine & Drivetrain 21 November 22nd, 2008 05:19 AM
Anyone have a link to a how to for secondary clutch spring? ojcool Brute Engine & Drivetrain 2 August 8th, 2008 11:19 PM
Secondary clutch spring compressor tool Aussiebrute Brute Engine & Drivetrain 6 April 26th, 2008 12:09 PM
Secondary clutch spring compressor. shawn3806 Brute Engine & Drivetrain 0 December 31st, 1969 08:00 PM
