June 18th, 2008, 08:16 AM
noise from clutch
yesterday i noticed a pinging loose bolt kind of noise comming from the belt clutch housing. my belt light dosnt come on and the bike still rides ok. but if i put it in gear and get off of it she drives away on me, and the 2wd 4wd light is flashing back and forth, anybody had this problem before,
05 Brute 750: 11:5:1 JE PISTONS, WEBB CAMS, FULL MUZZY, VFJ STAGE 3 Clutch, 2" LIFT, COPPERHEAD, CENTRE SNORKLES, K&N, DYNO JET and DYNO TUNED. 2009 SUNBEAM RED PLASTICS. 28" ZILLAS, STAINLESS STEEL BRAKE LINES
June 18th, 2008, 08:18 AM
noise from clutch
You need to pull your clutch cover and take a look inside. The belt is a top cog design and sometimes the top cogs may start to seperate and peel off. If so, it would have tripped your belt sensor, and pieces of belt could be binding in the sheaves, causing the roll away condition. Let us know what you find.
June 18th, 2008, 08:56 AM
noise from clutch
the belt light hasnt came on yet, what about the 2wd 4wd flashing back and forth? and the bike running away when its in gear?
June 18th, 2008, 05:09 PM
noise from clutch
took the belt cover off and there was nothing out of the ordinary clean as a whistle, took it to the dealer and he said it was the spider assembly it was worn out i guess, new one $157.00 not bad i guess, as for the 2wd 4wd flashing back and forth i have no idea what that can be anybody had that problem before im sure it must be electrical some what?
June 18th, 2008, 06:04 PM
noise from clutch
Hmmm You know, I've noticed some hairline cracks in my spyder assembly and primary clutch spring cover as well. I wonder if that is what is causing my belt slippage and the noise I hear when I punch it while in water or mud in high gear.
June 18th, 2008, 10:03 PM
noise from clutch
2wd/4wd light could be your kebc actuator motor going bad. I completely removed the kebc fork from my clutch cover. Didn't need it after the vforcejohn stage 3 clutch with spider mod anyhow.
June 19th, 2008, 10:43 AM
noise from clutch
could i just remove mine without the mod what will it do without an engine brake?
June 19th, 2008, 11:20 AM
noise from clutch
could i just remove mine without the mod what will it do without an engine brake?[/b][/b]
yes
June 23rd, 2008, 03:51 PM
noise from clutch
if i remove the fork is there going to be any change to the handling or braking to the bike will it be harder on belts, basically what will be the side effects, kawi must put that brake on for a reason,
June 23rd, 2008, 07:47 PM
noise from clutch
Just rode mine yesterday for the first time since I removed the KEBC fork. Take it off, you'll never miss it. The engine brake works just like normal until you get down to about 5-8 mph then it completely lets go. The fork simply applies pressure to the belt at low speed to force it into contact with the clutch sheaves. Take it off and try it. If you don't like it put it back on. It only takes a few minutes to remove and re-install. I like mine without it better and I was told by Interstate Motorsports that belt life is better without it.
2005 brute force stuck in 4x4, 2005 kawasaki brute force 750 clutch making noise, brute 750 noisy clutch, brute force 4x4 switch grounded, brute force 750 clutch noise, brute force 750 engine brake making noise, brute force clutch no turn, brute+force+kebc+actuator+making+noise+while moving, clutch for 2007 750 brute force, engine noise on 750 brute force, installing metal clip on prairie 360 acuater, kawasaki 360 prairie 4x4 light flashing, kawasaki 4x4 and 2x4 lights blinking, kawasaki brute clutch noise, kawasaki brute force 650 crankshaft sensor, kawasaki brute force 750 noisy clutch, kebc noise squeal, kebc on brute making noise, noisy brute force engine, powered by vbulletin oil light kawasaki brute force
Clutch Noise?
Dagan |
Brute Engine & Drivetrain |
10 |
May 6th, 2009 12:23 AM |
clutch noise
bigdog77 |
1 |
December 24th, 2007 08:15 AM |
Noise?????
bruteboy101 |
1 |
March 9th, 2007 09:10 PM |
