Old March 14th, 2007, 04:55 PM   #1
Default splicing in the toggle switch
I mounted a Warn 2.5 winch on my 650, routed all of the connections to the junction box and battery, but I still need to splice a red/black 12 ga. wire coming off the toggle switch into an ignition controlled wire. Which one she I use?
Thanks in advance.
t-rex is offline
Old March 14th, 2007, 06:11 PM   #2
davem's Avatar
Default which hot wire
i used the one going to the power outlet on the front left side. worked out fine
'07 BLACK BF 650 4x4I, PENLOC
SS106 , 26" TERRACROSS
K&N W/OUTERWARES, WARN 2500
EPI PINK & ALMOND SPRINGS
davem is offline
Old March 14th, 2007, 11:28 PM   #3
mudlift's Avatar
Default Re: which hot wire
Originally posted by davem
i used the one going to the power outlet on the front left side. worked out fine[/b]
Me too.
2010 Teryx LE
CLICK HERE FOR THE BEST BRUTE FORCE LIFT KIT ON THE MARKET!
http://www.ssatvplus.com
mudlift is offline
Old March 15th, 2007, 11:04 AM   #4
Thats a great idea...thanks davem and mudlift for suck quick responses.
t-rex is offline
Old March 15th, 2007, 03:07 PM   #5
I suggest you splice into it on the harness side of the connectors rather than the removable side. If you splice after the connectors you won't be able to remove that black shroud that the aux outlet sits in.
07 750 - Lime Green
BigReub is offline
Old March 24th, 2007, 08:28 PM   #6
me 3
www.StarCityATV.com www.Big13ATVClub.com www.WoolwichWheelers.com
07 Can-Am 800 Outlander H.O. XT - HMF Yellow Pipe-Power Commander-Dalton Clutch Kit-ITP SS 106 W/ 27" XTR's-Ricochet Full Skids-Hot Grips-2500 Warn Winch-Mobil 1 MX-4T
07 Can-Am 800 Outlander H.O. - HMF Red Pipe-Power Commander-Dalton Clutch Kit-ITP SS 106 W/ 27" XTR's-Ricochet Full Skids-Hot Grips-2500 Warn Winch-Mobil 1 MX-4T
05 750 Brute Force - HMF Pipe-Dynojet-Dalton Clutch Kit-ITP SS112 W/ 27" XTR's-Penlock-Skull Shifter-Twin Air-Mobil 1 MX-4T
05BruteForce750 is offline
Go Back   Brute Central Forums » Brute Forums » Brute Chassis & Electrical
how to splice a toggle switch in
splicing toggle switches
Backfeeding power via toggle switch to the gear shifter reverse switch KPC Brute Chassis & Electrical 6 January 24th, 2008 03:18 PM
Fan Switch Mud4Fun Brute Chassis & Electrical 3 January 2nd, 2008 08:53 PM
fan switch brutster Brute Chassis & Electrical 13 September 18th, 2007 11:17 PM
Toggle Switches johnny010 ATV Accessories 6 May 14th, 2007 05:59 PM
