Rear Shocks Adjustment - Kawasaki Brute Forum
post #1 of 25 Old November 11th, 2011, 12:28 PM
17A
Guest
Posts: n/a
Where would be the best place to position a jack to raise the rear tires off the ground so I can remove them in order to adjust the rear shocks to a firmer position. No way of getting the wrench on the shock cams without taking the wheels off as far as I can see on the Brutes. Front wheels no problem, just the rears. Should I place the jack directly under the rear diff skid plate with a wood block to widen the load pressure a bit or somewhere else? Don't want to damage anything by bending it. Further, to stabalize the machine I will put chocks on both front wheels and leave the tranny in gear rather than neutral. Should I also apply the front brakes by strapping the right brake lever? (Fronts). I am using a jack with a saddle approx 3" diameter.
Thanx for the help.
post #2 of 25 Old November 11th, 2011, 12:37 PM
Use a piece of board as wide as the skidplate to distribute the load.
I had to get someone to pull up on the rack and push their foot down on the tire to get mine to turn. You can also take a big pair of channel locks (waterpump pliers) and squeeze a few of the coils together to take some of the tension off. Use a rag if you care about scratching the coils.
2010 Brute Force 650i - Smoky Blue
1999 Grizzly 600 - Blue Smoke
gcfishguy is offline
post #3 of 25 Old November 11th, 2011, 02:32 PM
Coolwizard's Avatar
Just put the jack under the rear with a small board to relieve the pressure on the springs. I didn't need to remove the wheels to adjust mine.
26"Big Horns on ITP 312's, Viper Max 4000lb winch, Kawi rack extentions, Voyager GPS/gauges, Rogue grips
26" Big Horn 2.0 on ITP 112's, ASR a-arm bushings, Muzzy Super Pro Duals , MSD with VFJ tune, TTO oil & water temp gauges, Rogue grips
22" Swamplites on ITP aluminum wheels, 1.5" wheel spacers, DG front and rear bumpers, Fly Racing bars with Rogue grips, Power Madd hand gaurds, FMF pipe.
Coolwizard is offline
post #4 of 25 Old November 11th, 2011, 05:33 PM
17A
Guest
Posts: n/a
Thanx man, that worked like a charm. Made it very easy to turn the cams without removing the wheels. I was used to the Outlander and could eaqsily adjust the shocks without releiving pressure on the springs...
I set the pre-loads to one level down from the stiffest setting to see if that will help eliminate some of the tendancy for the machine to roll to the outside on power slides. had them mid range before and still had to watch cornering with very aggressive body english. We're riding tomorrow so I will post the results here.
post #5 of 25 Old November 12th, 2011, 12:00 AM
DLB
DLB's Avatar
I keep my shocks set one up from the softest setting. Seems to work well for my riding, and I completely agree about the wider stance. Aftermarket tires and wheels make a huge difference in handling and stability over the stock setup.
Teryx4 EPS | Suzuki LT80 | Brute Force 750
...and several others since 1988
My Garage
YouTube links:
DLB | ElkRiverOffRoad
DLB is offline
post #6 of 25 Old November 14th, 2011, 07:44 AM
17A
Guest
Posts: n/a
Well stiffening up the shocks to 2nd Highest position did make an improvement to the handling of the machine. Here is a video from Saturday going at fairly high speeds down a winding logging road. Did an unintential jump at 1:08 if you can see it.
Hunt Road Speed Test
post #7 of 25 Old November 14th, 2011, 06:04 PM
Mine are at their highest adjustment and here is the tool for the job. You can get one from SSATV here on the site.
Click image for larger version
Slumlord is offline
post #8 of 25 Old November 14th, 2011, 07:18 PM
Gota get me one of those...My channel-locks are screwing-up my chrome...lol
15 ZF 800
06 BF 750
post #9 of 25 Old November 16th, 2011, 11:00 PM
It was cheap and does a great job. Mud makes them himself...
Slumlord is offline
post #10 of 25 Old November 18th, 2011, 09:07 AM
should have that tool in kit under seat
2007 Brute Force 750
28" Mud-lites on stock rims
2500lb Warn Winch
K/N Filter,Mudinblood Snorkles
Pro-Armor Skids,Dyna Tec
bruteken is offline
Go Back   Kawasaki Brute Forum > Brute Forums > Brute Chassis & Electrical
adjusting shocks on brute force
adjusting shocks on brute force 750
brute force 750 shock adjustment
brute force shock adjustment
brute force shock settings
brute force shock upgrade
brute force suspension adjustment
brute force suspension upgrade
how to adjust brute force 750 shocks
how to adjust brute force shocks
how to adjust shocks on a brute force
how to adjust shocks on brute force
