Forum Members: 8,024
Total Threads: 7,311
Brute Central Forums » Brute Forums » Brute Chassis & Electrical » Brute Force 750 steering problem
Old August 29th, 2011, 10:23 PM   #1
Fordgasm250's Avatar
Default Brute Force 750 steering problem
i have a 2012 750 brute eps.... my steering locked up on me less then 30 hrs on it, kawasaki had it for a month, thought it was the electric power steering, replaced it and still did it had a engineer come out and said it was the front diff lockin up, replaced that and i finally got it back and rode it 10 miles and it locked up on me again. They told me its the first time they have ever seen this or had this problem and i was wondering if anyone has seen it or heard of it........
2012 750 brute 14 in SS212 wheels, 27" itp terra cross, hmf swamp series exhaust, hmf efi optimizer, k&n filter
Fordgasm250 is offline   Reply With Quote
Old August 30th, 2011, 08:24 AM   #2
rmax's Avatar
i do not know any thing about the sterring on the new ones ,an have not seen any post on other forums about sterring problems , but i do know the outer cv joints on the front axles will make it seem to lock up if they are dry or bad ,seems highly unlikley since the machine is so new , but stranger things have happened
06 650i, 29.5 skinny laws,warn 3000 winch,relocated rad,oil cooler,oil press ,water temp,an oil temp gauges, fst 85mm 11.5 to 1,fst stage2 cams,dynafs ing,head porting,front mounted reciver hitch(works well moving trailers) full hmf exhaust .rmax manual 4wd, ez steer
rmax is offline   Reply With Quote
Old August 30th, 2011, 08:25 AM   #3
DLB
DLB's Avatar
That's a first for me too. The 12' Brute is a new design, but not so removed from the previous design that there should be bugs to work out. What kind of oil are you using in the front diff?
Teryx4 EPS | Brute Force 750 | Suzuki LT80 | My Garage
WVGrizzly | ElkRiverOffRoad
DLB is offline   Reply With Quote
Old August 30th, 2011, 08:54 AM   #4
New to me too...no one on any other site I visit has had any issues with the 12 even on MIMB. I would say its something they are not looking at...maybe electrical not machanical. It is speed controled so maybe a bad speed sensor or connection. Somthing simple probably.
EZ-Steer EPS | Elka Stage-3 Shocks | Dynatek CDI |TwinAir Filter | Catch Can | Perma-Cool Oil Cooler | Diamond "G" Tie Rods & Ends | Energy Swaybar Bushings | OMI Stem Bushing | Ricochet Skid Plates | HL Bumper | Direction2 Overfenders | 26" Grim Reapers on 14" SS112s | Tons More Stuff!
NMKAWIERIDER is online now   Reply With Quote
Old August 30th, 2011, 09:35 PM   #5
Not to sure what kind of oil they put it in, i mean its a brand new front diff just installed aweek ago by dealership under warranty, rode 10 miles and broke again, theyve replaced the power steering unit and 4 wheel drive actuator already to, i havent put it in 4wd either time so yalls guess is good as mine
Old August 31st, 2011, 08:59 AM   #6
rmax's Avatar
do they have a lemon law in your state,
Old August 31st, 2011, 09:29 PM   #7
yea we are looking into the lemon law, i think it has to break 3 times for it to fall in affect
Old September 2nd, 2011, 06:36 PM   #8
12bf's Avatar
I have a 2012 brute works great so far, Let us know when they find out whats wrong that would be good some good info right there.
2012 Brute 750 eps se
Terracross 25x10x12
Terracross 25x8x12
1" Spacers
Uni filter
My videos...
12bf is offline   Reply With Quote
Old September 5th, 2011, 10:20 PM   #9
just a update guys i found both front axles broke, so took it back to kawasaki they say it was a new problem but im thinking its been that all along, the joints are broke and only way to see is if ya remove the axle boots like i did
Old September 6th, 2011, 08:16 AM   #10
STOGI's Avatar
My question is how could broke axles interfere with the powersteering? Not saying it couldn't .. I'm just interested in how.
BF750 Built For Business
Stock is for pansies.
STOGI is offline   Reply With Quote
Go Back   Brute Central Forums » Brute Forums » Brute Chassis & Electrical
2011 brute force 750 problems
2011 kawasaki brute force 750 problems
2012 brute force 750 oil filter
2012 brute force 750 problems
2012 brute force problems
2012 kawasaki brute force 750 problems
brute force 750 forum
brute force 750i problems
brute force steering
brute force steering problems
SEO by vBSEO ©2011, Crawlability, Inc.
