June 24th, 2010, 12:10 AM
08 Brute Force wont run
HI there,
I have an 08 brute force 750 with the fuel injection. The other day it ran fine and i went to start it today and it will not start unless i pump the throttle alot. I hear the fuel pump start up when i turn the key and when i go to start it, it will not start. Then after i pump the throttle it finally starts but runs really rough. Then when i put it into gear it dies. Anybody every had this problem? I talked to a mechanic and he said ECM? Also he told me he thought kawasaki had a recall on this?
Thanks
June 24th, 2010, 01:34 AM
Originally Posted by EasyE
HI there,
Thanks
Seems I hear about more 08s and fuel pump problems then any other injected year. But..the majority of these are intake screen related. Some have been able to pull the pump, clean it out, then clean out the tank and reinstall. Gus in Greece had this problem and after he found a drop-in filter that catches all the stuff that enters the top of the tank.
Might pull the fuel line off the rail and see how much volumn and pressure it has with the key on. If weak, then look to the pump or it's intake. If nothing...well...maybe be the controler or ecm/ecu.
June 24th, 2010, 06:48 AM
Yeah,check your pump for dirt inside...mine had a lot inside....i did not have the same problem though.Mine started with no problems,ran fine but did not have top end speed...anyway,a check won' hurt...
June 24th, 2010, 09:52 AM
How dirty is the air filter?
08 brute force 750 fuel problems, 08 brute force problems, 08 brute force with dynatek, 08 kawasaki brute force 750 fuel pump problems, 2009 brute force wont start, 750 brute force wont start, 750 kawasaki brute force want start, brute force 08 wont start, brute force 750 runs rough, brute force 750 wont start, brute force fuel pump wony turn on, brute force wont run, brute force wont run after new fuel pump, brute force wont start, kawasaki 750 brute force wont start, kawasaki brute force fuel pump proublem, kawasaki brute force fuel pump wont start, kawasaki brute force wont run after installing new fuel pump, kawasaki brute force wont start, problems with 2010 brute force
