How to wire a winch on a brute? - Kawasaki Brute Forum
 2Likes
post #1 of 28 Old September 25th, 2008, 04:32 PM Thread Starter
07galaxy650's Avatar
I ordered me a winch for my 07 brute force, but it hasnt come in yet. Just trying to get an idea of how it wires up. I put one on my uncles 360 prairie, and it was simple. Where on the brute do you put the solenoid? Thanks.
07galaxy650 is offline
post #2 of 28 Old September 25th, 2008, 05:11 PM
Re: How to wire a winch on a brute?
I put mine where the tool kit was.
Click image for larger version
File Type: jpg_thumb picresized_th_1222415925_DSCF0321.jpg_thumb (142.4 KB, 9 views)
mudlift is offline
post #3 of 28 Old September 25th, 2008, 05:22 PM
I also removed the tool kit and installed it in its place.
jaup09 is offline
post #4 of 28 Old September 25th, 2008, 05:28 PM
shawn3806's Avatar
Same for me also.
shawn3806 is offline
post #5 of 28 Old September 25th, 2008, 05:47 PM
gusmx5's Avatar
i have installed 2 winches on my 08 and my friends 06 brutes and it is very easy.
If you want you can connect it straight to the battery,red on red and black on black.The small box that comes wtih the winch i put it in the front of the atv,behind the radiator and under and little front the steering bar where is a lot of space and you can tie it firmly with anything you think it will hold..
From there it is easy for the wiring to go down to the winch,it is only 30-40 cm and up to the battery which is little longer.
You can cut in half the tube that the brute has for this reason on the left and next to the battery(the 08 only has it) and send down the cable for the winch and up to the battery.With this way you do not have to take of the tools from the space they are supposed to be.
Also you can wrap the "box" with a nylon bag and wrap it around with wiring tape to make it water proof.So far i do not have any problems...
gusmx5 is offline
post #6 of 28 Old September 25th, 2008, 06:10 PM
gusmx5's Avatar
Mudlift can i ask you a question?All these wires that i see on your photo are from the winch?And if yes why so many?Mine had 4,2 for the winch and 2 for the battery...
And a question for everyone,my winch is 2000 lbs and my friend&#039;s too but they are weak...
I read on the site of superwinch that for the winch to perform as it should and give out 2000 lbs it needs 100 amps battery,is it true?Because our battery is small,only 14 amps and if you do the math....
Any answers?
gusmx5 is offline
post #7 of 28 Old September 25th, 2008, 07:56 PM Thread Starter
seems like a good spot to me. :peace: On my uncles, I put it inside the rear storage box, worked pretty good. Has anyone mounted it anywhere else? Mudlift- What did you do with your tool kit?
post #8 of 28 Old September 25th, 2008, 11:23 PM
Any answers?[/b]
I have a 3000# WARN on mine. 2 go to the winch & 2 go to the battery.
mudlift is offline
post #9 of 28 Old September 26th, 2008, 07:56 AM
gusmx5's Avatar
I agree but what about the power of it?Does it perform as a 3000 lbs winch or it is weaker?
What do you see?
gusmx5 is offline
post #10 of 28 Old October 6th, 2008, 12:41 AM
bustamove's Avatar
i put my relay just under the battery on the plate. seems to be working okay soo far...i will post pics soon.
08 750i, 26" bighorns 2.0 on itp 108ss. Ricochet full armor. warn 2500RT winch, 2"SS atv lift,engine snorkeled. BLUE back lighting for pod, PIAA lights, HID lights, heated grips, water temp gauge, oil pressure gauge, custom rear rack(flat pack), EHS racing lid, poly upper a arm bushings. big guns full system, msd. zerk's on every suspension joint, dis-connectable sway bar
bustamove is offline
Go Back   Kawasaki Brute Forum > Brute Forums > Brute Chassis & Electrical
Spark Plug Wire - Can I fix it or do I need to order a new one? Waterfreak66 Brute Chassis & Electrical 2 May 17th, 2008 09:30 AM
Keyed power wire kraazie8 Brute Chassis & Electrical 7 April 22nd, 2008 08:52 AM
Whats this wire? BassMaster Brute Chassis & Electrical 7 April 17th, 2008 10:40 PM
How to wire additional headlights? machinewars Brute Chassis & Electrical 4 August 1st, 2007 06:03 PM
How do I wire a horn to my quad ? esquared General Discussion 14 December 9th, 2006 11:17 PM
