February 5th, 2008, 10:35 AM
Has anyone tried making there own skid plates?
I was thinking about using the stock Plastic skids as a template, and making copies out of 1/4 aluminum. I just need to find a sawzall blade, or cutting wheel that will cut aluminum. The front skid will probably be the hardest, so I think I will start with the center, then rear. Any ideas?
2006 BruteForce 650i
26" Mudlite XTR's, wrapped around 12" ss112 wheels
Warn 2.5ci
Almond secondary
Auto meter temp guage
February 5th, 2008, 10:39 AM
I made all mine.
http://rides.webshots.com/album/559637127hfHnkM
I found that a skill saw with the orbital stroke and a 10 tooth blade worked the best. Much easier to control than the Sawzall. Even without the obital stroke, low speed is the key to keep the blade from loading up. Also, spray some silicone lube on your cut path, it also helps the chips release from the blade.
February 5th, 2008, 03:47 PM
Plus, you don't want to use a sawzall for precise cuts...they're more for rough cuts....
Tom D
February 5th, 2008, 05:38 PM
I made my own skids and they worked out great. My front skid is similar to the one on the lifted brute on the brutecentral home page. It was rather easy to make them all. I used a skill saw and a jigsaw that worked excellent. I would highly promote doing it yourself if your somewhat mechanical. I haven't made the CV boot sheilds yet but I will once the snow is gone. I did find that the quad is louder now. It seems to echo of the aluminum checker plate that I used, but well worth it. I was amazed at how bashed up the skids get.
February 5th, 2008, 09:51 PM
I remember someone on here saying they made theirs from old road signs.
February 6th, 2008, 10:55 PM
I remember someone on here saying they made theirs from old road signs.[/b][/b]
Yeah, I think I remember seeing that somewhere too.
Warn 2.5ci
Almond secondary
April 1st, 2008, 09:07 AM
Made mine out of 11 gauge steel. Plasma cutter, grinder, and a drill.
06' 650 Brute SRA
Radiator Relocate, Snorkeled, Custom Skids,
27" Mudzillas,2" Lift
April 1st, 2008, 11:08 AM
i bought mine off ebay. cost me 250 bux. I didnt have the time to make mine. But so far so good. Also i have seen guys use 1/4" puck board and say it takes a beatin like no tommorow.
2006 CAMO BF 750I</span>
Center Snorkels, Moose Module, Muffler Mod
Marron primary/Almond secondary
27" Gators on ITP C4(soon 29.5 swamp lites)
<span style="color:#0000ff">48" plow, synthetic winch line.
April 1st, 2008, 03:04 PM
Sometime this year, I'll be making one out of puckboard (I already have the puckboard at home). I'm going to make it a single piece, as apposed to three. I'll post pics and specs when I get it done.
Cheers
Chris
April 3rd, 2008, 01:05 AM
I used puckboard on my old honda and it worked out great. Slides over snow better than aluminum and is actually quite tough.
Black 07 650i,26''mudbugs..Quadboss rear seat..moose handguards
ss112's,maroon primary,swaybar gone,Moose Module,Symtec Heated grips,Warn front bumper
Direct2 Overfenders
06 skid plates
wvMOUNTAINMAN |
Brute Chassis & Electrical |
2 |
February 10th, 2009 06:51 PM |
skid plates
4x4kingx889 |
Brute Engine & Drivetrain |
4 |
January 22nd, 2009 10:48 PM |
skid plates
highcountryrider |
15 |
January 21st, 2009 02:11 PM |
Skid Plates
Sleepy |
5 |
December 27th, 2007 11:00 PM |
skid plates
ridesdirt |
3 |
December 21st, 2006 10:50 PM |
