July 30th, 2010, 11:46 AM
winch cable with rubber/plastic coating
Has anyone tried using a cable with a plastic coating on it? Something like a clothes line cable? I like having a cable (not rope) on my winch, but the elements my winch goes through (mostly mud) beats the hell out of my cables. A coating will keep the water and muck off the cable and prevent some/most of the fraying.
July 30th, 2010, 04:28 PM
Seems like a good idea. I think I read somewhere that it had issues with wraping tightly and taking up too much room on the spool though.
July 30th, 2010, 08:51 PM
I don't think it would last long going over the roller fair lead with tension on it.
August 2nd, 2010, 12:24 PM
Especially so if you live in cold climates and use the winch.
2007 Brute 750i
Warn XT-30 Winch
Fender Flares
August 2nd, 2010, 10:10 PM
actually the cable will not even last as long as the exposed cable. The coated cable still gets mositure inside the shell and wet and cannot dry out. The exposed cable is open to the sun and air and the mositure will evaporate. I have seen coated cables rust clean into in about 1/2 the time comparded to exposed naked ones. Unless they have come out with something new I don't know about...
August 3rd, 2010, 10:04 AM
Thanks for the feedback guys. I will stick with the stainless cable...
750 brute force winch cable, atv winch rope plastic coated, clothesline, coatings winch cable, plastic covered winch atv cable, using a winch for clothesline, using coated cable in atv winch, winch cables rubber
