January 8th, 2010, 10:10 PM
Warn 2.5 ci repair/rebuild
My warn needs some tlc. My question is simple. What kind of grease should I use on the planetarys and such, and is there anything that I need to know about before disassembly or reassembly? Hope someone here can answer these questions, So thanks in advance!
Josh
2006 BruteForce 650i
26" Mudlite XTR's, wrapped around 12" ss112 wheels
Warn 2.5ci
Almond secondary
Auto meter temp guage
January 8th, 2010, 10:20 PM
Josh
Lubaplate or white lithium or mairine wheel bearing greese works well. Just take your time and lay things out as you take it apart. They arn't too bad.
January 8th, 2010, 10:28 PM
Thanks for the reply, I really appreciate it!
Warn 2.5ci
Almond secondary
January 14th, 2010, 10:25 PM
Began the cleaning process!
Well, I disassembled the 2.5 ci, and found that their were no broken parts. Two out of 3 planetary sets had a couple of planets seized up, and lots of mud in the gear boxes, and inside the motor. After soaking the planetaries in a bucket of PB Blaster for a couple of days, the seized gears broke free, and spin very nicely. I have cleaned and recleaned all the gear sets, disasembled the motor, cleaned up the armature, brushes, and commutator. Next is careful reassembly, packing the gear boxes with lots of marine grease. I figure packing it with marine grease, will allow it to be more resistant to water and mud. Im also figuring that this complete clean and grease will probably be a yearly, or every other year, maintenance item. Just thought Id give you guys an update.:rocker:
Warn 2.5ci
Almond secondary
January 14th, 2010, 11:40 PM
Very cool. Any way to help seal out that stuff? Some extra RTV...
2.5ci warn winch seizing up, brushes on warn 2.5ci winch, greese a 2.5 warn winch, how do change brushes in warn 2.5ci winch, how do you clean the gear in 2.5ci, how to rebuild warn 2.5 ci winch, rebuilding 2.5 warn winch, rebuilding a warn 2.5ci winch, repairing warn winch what grease to use, replacing brushes in a warn winch 2.5ci, warn 2.5 ci rebuild, warn 2.5 rebuild, warn 2.5ci brushes, warn 2.5ci disassemble and grease, warn 2.5ci rebuild, warn 2.5ci repairing, warn 2.5ci winch brushes, warn winch 2.5ci brushes, warn winch motor rebuild, when reassembling a 2.5 ci winch do i pack it with grease
