Brute Central Forums » General Forums » ATV Accessories » Where to connect ground wire for heated grips?
Old December 16th, 2009, 09:52 PM   #1
DLB
DLB's Avatar
Default Where to connect ground wire for heated grips?
I'm almost done installing my new Symtec heated hand grips. All I need to figure out is where to put the ground wire. I have 2 options: I can either spice the ground into an existing factory ground wire or I can hook it to the frame somehow(expect I don't see how I can do this). This might be a hard thing to explain, but can anyone give me an idea of where I should ground this wire? Thanks.
2009 Brute 750
Almond Secondary | ASR bushings | Big Gun Evo System | Bighorns | GoPro HD Hero2 | HDPE Skids | ITP SS 312s | MSD FI Charge | Powermadd hand-guards | Prothane Sway Bar Bushings | Snorkels | Streamline Steering Stabilizer | Symtec Heated Grips | Temp Gauge | Viper Max 4500 | My Garage
http://www.youtube.com/WVGrizzly | http://www.youtube.com/ElkRiverOffRoad
DLB is online now
Old December 16th, 2009, 10:27 PM   #2
I mounted mine behind the pod on the handle bars. if you take the plastic off the handlebar you will see a couple screws. I just took one of them out and grounded the wire to that. I dont like splicing into existing wiring. especially grounds. any bolt that bolts to the frame or the motor will be grounded. you can mount it anywhere
05 Brute 750: 11:5:1 JE PISTONS, WEBB CAMS, FULL MUZZY, VFJ STAGE 3 Clutch, 2" LIFT, COPPERHEAD, CENTRE SNORKLES, K&N, DYNO JET and DYNO TUNED. 2009 SUNBEAM RED PLASTICS. 28" ZILLAS, STAINLESS STEEL BRAKE LINES
BRICKLAYER is offline
Old December 16th, 2009, 10:45 PM   #3
DLB
DLB's Avatar
I know the screws you're talking about. I actually looked at them, but I wasn't sure if that was good enough. Thanks! I agree about spicing into existing wiring, but how did you wire the red (hot) wire? I had to spice into the accessory plug. It seemed like the easiest way to go. I hated to do it, but I didn't think I had any other options.
2009 Brute 750
DLB is online now
Old December 17th, 2009, 12:34 AM   #4
blackbeauty's Avatar
I used the little plastic wire splicer and hookeed mine into the acc plug as well, just make sure you wrap it good so that no moisture gets in and causes corrosion.
Black 07 650i,26''mudbugs..Quadboss rear seat..moose handguards
ss112's,maroon primary,swaybar gone,Moose Module,Symtec Heated grips,Warn front bumper
Direct2 Overfenders
blackbeauty is offline
Old December 17th, 2009, 02:23 PM   #5
Thom's Avatar
I ground mine to the bolt that comes off the frame on either the left or right side on the top of the frame. if you take the housing off around the steering stem and look down you will see them. I could get a socket and wrench in there from either side over the tire.
Thom is offline
Old December 17th, 2009, 03:58 PM   #6
DLB
DLB's Avatar
Default Symtec grips not working!?
Well I got everything hooked up and grounded, turned the key...the symtec controller didn't light up. I tried putting something into the acc plug and it doesn't work now either. I checked the acc fuse under the seat and it was fine. I disassembled the plastic splice to see if the wires are still contacting and everything looks good. I have no idea what could be wrong. Any thoughts?
2009 Brute 750
DLB is online now
Old December 17th, 2009, 05:15 PM   #7
DLB
DLB's Avatar
Ok I figured it out. I tried another ground spot and it worked. The grips heat up quick! I just need to get a bigger ring terminal and I'll be gtg. The one they provide in the kit is too small for where I want to place the ground. Thanks for the help guys.
2009 Brute 750
DLB is online now
Old December 17th, 2009, 06:55 PM   #8
Good to hear. the AC terminal from the cigarette lighter plug is the best to hook to because when you turn the key off it cuts power.
Old December 18th, 2009, 09:37 AM   #9
DLB
DLB's Avatar
Roger that. Now I just need a good set of hand guards to help with the cold even more. Thanks again fellas.
2009 Brute 750
DLB is online now
Old December 18th, 2009, 09:46 AM   #10
I use powermadd but they are more for looks and sticks then deflecting cold air. Moose or I think Koplin or Kempex makes a better winter guard. There are some that you actualy stick your hands into. With gip warmers that would be awsome.
aheated grips on brute force 750
atv forums heated
brute force 750 heated grips
brute force heated grips
brute force heated gripsthe best
ground wore on rox handle grpi
heated grips brute force
heated grips brute force wiring
heated hand grips on a brute force
heated handgrips where to ground
installing heated handgrips on a brute force
installing symtec heated grips on atv
powered by vbulletin 16 gage stainless steel wire
symtec controller on brute force handlebars
where to connect heated grips
where to connect wires for heated grips on atv
