Old December 6th, 2009, 11:00 PM   #1
Default Gorilla/ ProMark winch
I have decided that I am going to use my Sportsman 400 for plowing, rather than the Prairie this winter. So, I just finished buying a bottom plate mount at Dennis Kirk. I need a winch, for raising/ lowering the plow, and needed one in general anyhow. I found this deal, on ebay.
http://cgi.ebay.com/ebaymotors/GORIL...item5d2680367f
I figure for that cost, with free shipping, I can't go wrong. I also bought a winch mounting plate for another $45, with free shipping, from them. $130 total for a 3000 lb winch. I did a quick google check on Gorilla winches and they seem to have good feedback. Time will tell, but if you need a winch..... this is the cheapest I have seen one, ever, that I can recall.
Old December 7th, 2009, 12:25 PM   #2
Thom's Avatar
Good deal. I have ehard good things about Gorilla's service as well.
Thom is offline
Old December 7th, 2009, 09:44 PM   #3
skip nay's Avatar
Never dealt with them. Hope it works great for you.
skip nay is offline
Old December 8th, 2009, 10:27 AM   #4
Coolwizard's Avatar
I've got a gorrilla on my brute. I've used it on several occasions with no problems. I had a gorilla on my prarie for about 4 years. I used it quite a bit for plowing and even moving a few logs. It recently died, the internal gears stripped. I will probably replace it with another gorilla because of the low cost.
Coolwizard is online now
Old December 8th, 2009, 07:13 PM   #5
If I get a few years out of it, I will be very happy. For for $84.99, I could buy four and still not even be at the cost of a Warn 3000lb winch. My first winch, ever, was a Warn A2500 that I paid $360 for, in 2003. I rebuilt it 3 times in three years and finally trashed it. I bought an Extreme 2500lb winch and it has worked without problem for the last three years. I bought the Gorilla as it was even less than the Extreme and seemingly good feedback.
extreme winch vs promark
extreme winch vs warn
pro mark winch
pro mark winch clicking
pro-mark vs warn
promark vs gorilla winch
promark vs warn
promark vs warn plow
promark winch --filetype:ps -filetype:dwf -filetype:kml -filetype:kmz -filetype:xls -filetype:ppt -filetype:doc -filetyp
promark winch seems stripped
warn plow vs promark
warn versus promark
warn vs moose atv plow
warn winch vs promark
